Wire crushed
Hulk smash wire. Car no start.
Are we talking about 2 different cars with different issues? These should be in different threads, possibly in different forums, we have SS specific forums.
You really should use the talk to text feature of your smartphone. Of course, proofread as you go. What you're posting is just too difficult to follow.
Trying to put things into context and stay criptic not easy
im on learning curve, if you're only interested in creteking keep in mind im not here to earn grade and as helpful as hinting a part only found on automatic transmission could be part of my problem could very well be true indication of just how far outside the box you have the ability to see
My problems are real and I seek the ability to look past the automatic transmission and a little closer to what's going on, maybe I have given too much information, need to slow down , type in all caps
Simple flow chart of knowledge that understands the difference between pushing a clutch and moving to D may be too much to ask ?
If you really need help you have to be clear. I don't have any idea what you are talking about.
All I got is you have a 2.2 a 2.4 and a 2.0 all different years and there is some problem with one or more of them that might have something to do with vandals; And you are upset that we don't understand stream of consciousness gibberish. I did manage to get through James Joyce's Ulysses and Finnegan's Wake 55 years ago, I'm too old now.
Car 06 HHR
Engine?
Will not start after changing clutch
Have looked at information for 06 2.2 in HHR and what I have not a match by sensor location
This Engine short 2 sensor by location. No cam sensor and no crank sensor ?
Engine?
Hulk happy !
Car engine no start
follow harness wiring for 06 hhr but stuff not there?
Car engine turn over
all fuses ok
smell gas, pump working
engine light on, reader says no codes
looking for crank sensor = not there
looking for cam sensor = not there
car no start
hulk sad
Car engine no start
all fuses ok
car no start
hulk sad
