Day 3..... I stunk it up on the way to work...it's been so windy. I rode my bike yesterday, so I didnt need to pull out the SS. I did put 42 miles on it, I only drank a half gallon out of my camelback....so thats 84mpg, can I count that??
TotalMiles. TripMile. Avg trip …...AVGMPH. TripMPH…. AVGMPG. TripMPG… FuelRange…. Projectedrange. %highway.. epa projected mlge.. Hypermile improvement over epa.. 108.1 ____ 12.5 ____ 13.5 ____ 37.0 ____ 37 ____ 35.9 ____ 33.1 ____ 467.0 ____ 581.58 ____ 75.80% _______ 27.1 _________ 22.3% to work 120.2 ____ 12.1 ____ 13.4 ____ 37.0 ____ 37 ____ 35.9 ____ 35.9 ____ 489.0 ____ 581.58 ____ 75.80% _______ 27.1 _________ 32.6% from work |
Originally Posted by Clevelandhhrss
(Post 296111)
Manual/automatic?
40 psi cold...wow, im under that on the hottest day, on the highway..... what is the terrain like near you length of average drive from cold start , to stop. Octane? Any tricks or techniques being employed. What speeds? the posted limits and what you actually drive. A/c? Window open? The 2.2 should do better then my 2.0, any mods on your car? Current odometer? Etc. Help, teach, learn contribute. Many here get in the low 20's lol. Help them out. Have you really gone more than 600 miles before a fill up? That would be sweet! |
This is interesting! I wish you could do a tank on almost all city driving rather than highway. Compared to my low 20's mpg, this looks amazing...but I do 95% city and average 18-20 mph. 75% highway driving is a totally different animal.
What I'd be interested in seeing is a fuel efficiency coefficient(?) (rating) based on your average mph, distance, mpg, etc., in order to extrapolate, for example, 22.5 MPG at 20 MPH into X MPG at 35 MPH. I've been trying to think of a way to do that, but got stumped. |
Originally Posted by calgaryhhr
(Post 296125)
The real trick to getting 40 mpg is to convert from L/100km to UK/Canadian gallons. The 40 mpg stated is actually 34 mpg in american gallons.
I've been bashed before for being too negative, or a know it all, so I let the conversion slide. 34.1mpg actually. I am seeking input, not just to correct others math. No problem, but as you can see ..you can do better if you have the inclination |
Originally Posted by wxman
(Post 296158)
One thing to remember is that I change my techniques based on the situation. For example, if I am stuck in city traffic, but the lights are short, I'll pulse and glide(coast), ill slightly annoy the drivers behind me, but we'll all get there exactly the same overall speed, and save a little gas. What is the point of racing to a red when you are 100% sure it will be red when you arrive. If the lights are long, ill cut off the engine until the cross light turns yellow, then turn the key and pull away in 1st........2nd on a downhill of course. If the lights are not always red, or I am the last to arrive at the light (happens a lot and i like that), I'll time them and maintain a constant slow speed, coasting and braking slightly , so that when it is green i can pull away in 2nd or 3rd while the gas hogs in front of me race of to the next red light.
All this means is that for nearly any situation short of new york cabbies (honking when the cross light is still green so you will be the first through) you can get 27+mpg. Pulse and glide is great in stop and go highway traffic, even better than cruise at 65. If you do stop for a long time, just turn your car off. Hint: make sure you turn your lights to manual from auto at night so as not to alert anyone to you gas sipping ways. later |
Lol...newsflash....get up too late to make breakfast, and Mcdonalds will crush your mpg.
I actually turned my car off three seperate times in the drive through (it is actually faster than walking in at this location) and use idle to pull forward each time. I probably doubled the mileage by this alone considering it took them 12 minutes from start to finish to get me fed. It would not be much of an experiment if I just drove back and forth to work at 36.3 mpg anyway, so I actually wanted to see how bad it would be. 17.6mpg is REAL BAD.. Anyway Now you know tat if you drive a couple of miles to the local drive through, and leave you car on the entire time, after a cold start up----12-17mpg is probably what your getting. Ill mix it up this weekend with some longer trips to see if i can do a 40mpg drive at some point. TotalMiles. TripMile. Avg trip …...AVGMPH. TripMPH…. AVGMPG. TripMPG… FuelRange…. Projectedrange. %highway.. epa projected mlge.. Hypermile improvement over epa.. 132.3 ____ 12.1 ____ 13.2 ____ 38.0 ____ 51.9 ____ 35.7 ____ 33.8 ____ 449.0 ____ 578.3 ____ 75.80% _______ 27.1 _________ 25.0% to work 133.4 ____ 1.1 _____ 12.1 ____ 37.0 ____ 8.9 ______ 35.4 ____ 17.6 ____ 442.0 ____ 573.5 ____ 0.00% ________ 21.0 _________ -16.2% cold start to mcdonalds drive through and back 145.3 ____ 11.9 ____ 12.1 ____ 37.0 ____ 37.0 ____ 35.5 ____ 36.7 ____ 409.0 ____ 575.1 ____ 75.80% _______ 27.1 _________ 35.5% from work |
Day 5? i think...lol Mysteriously my trip to and from work has dropped from 12.2 miles to 12.1 then 11.9 and now 11.6. I think I have discovered a worm hole in route 90.
TotalMiles. TripMile. Avg trip …...AVGMPH. TripMPH…. AVGMPG. TripMPG… FuelRange…. Projectedrange. %highway.. epa projected mlge.. Hypermile improvement over epa.. 145.3 ____ 11.9 ____ 12.1 ____ 37.0 ____ 37.0 ____ 35.5 ____ 36.7 ____ 409.0 ____ 575.1 ____ 75.80% _______ 27.1 _________ 35.5% from work 157.3 ____ 12.0 ____ 12.1 ____ 37.0 ____ 37.0 ____ 35.3 ____ 33.0 ____ 407.0 ____ 571.9 ____ 75.80% _______ 27.1 _________ 22.1% to work 168.9 ____ 11.6 ____ 12.1 ____ 38.0 ____ 60.0 ____ 35.2 ____ 33.9 ____ 405.0 ____ 570.2 ____ 75.80% _______ 27.1 _________ 25.3% from work Ignore the trip mph....as the mileage racks up, the resolution of the avg mph (1mph) is screwing with the split odo (0.1mile) so this parameter will be inaccurate. |
Ok I am not trying to a smartelic but just making a statement. I drive 31 miles one way to work as of right now I am getting 32.6 mpg NOW when the wife drives we get about 29mpg but I have noticed that she likes to accelirate quikly when she takes off. Will that alone explane the milage differance?
Originally Posted by kwboydston
(Post 297278)
As for the wormhole on I90, they filled in some potholes, decreasing the up and down distance. Potholes in Cleveland have been known to swallow cars. :eek: And.... a Real engineer would have posted an Excel spreadsheet with graphs. :p: |
