Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Air Filter / MPG improvments ?
Old Jul 6, 2010 | 06:04 PM
Daytonablue06's Avatar
Originally Posted by Doc brown
The best advice is to ease off on the gas pedal a bit. No hard accelerations, whenever possible run at 60 instead of 65, 65 instead of 70, etc.
ugh now what fun is that hehe
Old Jul 12, 2010 | 09:45 AM
RICK167448's Avatar
Smile Tweeking my HHR
I used a Fram air cleaner filter, Bosch Platinum Plus 2 spark plugs, Mobil 1 5-30 synthetic oil with a Fram CH9018 oil filter, fuel system cleaners in each tank of gas, 40 psi in my tires, and I put it in nuetral when I am going down hill, I get about 33 mpg. My car has 25,000 miles on it. Trust me, these changes needed to be made to improve the gas mileage and the performance.
Old Jul 12, 2010 | 10:21 AM
JoeR's Avatar
Fram filters aren't exactly known for any quality these days. Well documented.
The Bosch multiple electrode plugs aren't the best either and are inferior to the newer Iridium plugs, such as the OEMs.
GM does NOT recommend fuel additives. The mandated additives today are fine.
40 PSI may lower rolling resistance slightly but expect a harsher ride and more wear in the center of the tread as a result.
Putting the car into neutral going downhill is useless, in fact will result in LOWER mileage. When in neutral, the ECM is still providing fuel to prevent a stall. These newer cars have a programmed "feature" called DFCO (Decelleration Fuel Cut Off) that will cut off all fuel during most coast down conditions. It is done for both fuel mileage and emissions.
Old Jul 12, 2010 | 10:39 AM
urbexHHR's Avatar
Then why does the mpg's go up on the DIC?
Old Jul 12, 2010 | 12:17 PM
JoeR's Avatar
Some thoughts to ponder....
1. Put car into neutral: Gas is fed to prevent stall. (not much though)
2. Leave in gear: NO gas during DFCO, where NO gas is fed.
Now which do you think uses more??
Old Jul 13, 2010 | 10:24 AM
urbexHHR's Avatar
But if no gas was fed, wouldn't it stall?
Old Jul 13, 2010 | 10:40 AM
JoeR's Avatar
Yes it would. However below a certain RPM or speed in gear, the fuel will resume to prevent a stall during coastdown.
RBodeman
2.0L Performance Tech
10
Oct 9, 2012 09:49 PM
asherdav
Maintenance and Upkeep
25
May 8, 2010 10:39 PM
dvalin
Mar 25, 2008 02:47 PM
