low fuel on dic
I notice on the GM products I have had or have, the low fuel light will come on when my range is down to the 50 mile mark. If you run out, I understand you will need to put in at least 2 gallons in order for it to restart, 1 gallon will not do it. I generally will not let my tank go below the 1/4 mark.
I generally fill up when I get to 1/8 of a tank left, over time you get a layer of contaminants in the bottom of the tank. Running it to the last drop can suck up the contaminants and make the fuel pump work harder than it should along with the possibility of sending a batch of crud to the injectors.
I'd trust the gauge more than the DIC, but the low fuel alarm can get your attention so you fuel up before its too late.
