Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
my mpg has been going down alot
Old May 13, 2009 | 05:17 PM
GrotesqueFetus6's Avatar
for some reason after i did my oil change the DIC says im getting 16-18 mpg in city and 22-24 on the highway
my engine is sucking on the gas tank like its a big gulp!! WTF.
and yes im easy on the go with rpms under 2500 and high way speeds at 65 max
i just dont get it . it used to get 25 city and 32 high way.
i had to fill up twice this week with my normal driving like i do EVERYWEEK
i only had to fill up every week and a half before i got my oil changed . is there something i need to change i dont know about ?
im going to change the air filter tomorrow . and i put a new oil filter in when i did a change with the right amount of oil
just so everyone knows
Old May 13, 2009 | 06:11 PM
catdaddy137's Avatar
oil
what type oil did you use?
Old May 14, 2009 | 04:34 PM
penzoil
Old May 15, 2009 | 05:12 AM
masterchief1112's Avatar
what weight?
Old May 15, 2009 | 06:08 AM
More_Torque_More_HP's Avatar
Check you tire pressure. Keep it near the maximum pressure
Old May 15, 2009 | 06:56 PM
oil
synthetic oil does make a difference , as well as the weight...i'm using 0w-20w oil now , and i think i will continue , since i found that it increased my mpg...i will also cotinue to use napa gold air filters , unless i install a cold air intake...my mpg is aways above 30 now even if i mix some 80mph runs in on my route.
Old May 15, 2009 | 10:34 PM
hmmm ill have to try that on my next oil change
Old Jul 10, 2009 | 03:15 AM
dkenthoward's Avatar
you also might check the blend and use gas without ethanol....it made a difference with mine...
Old Jul 10, 2009 | 11:51 PM
Hamer1's Avatar
Recently I had the check engine light come on. Before that I noticed the fuel economy getting worse. When I took it to the Dealer they told me one of my injectors was bad. They replaced with the new version? Mine is a 07 2.4. After that it is getting better MPG than when I got it.
jas89tta
Sep 17, 2009 07:59 PM
