Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
Oxygen Sensors Help
Old May 3, 2022 | 08:21 PM
Actually, both of those codes indicate a wiring problem. P0136 is for the circuit and P0137 is for low voltage; that means a wire is compromised or the fuse is blown.
Other possible causes are bad flex pipe or some other air leak between the intake manifold and the #2 O2 sensor.
Way down at the bottom of the list is a bad sensor.
Why replace a part because it is mentioned in the title of an OBD2 test?
Old May 3, 2022 | 08:33 PM
All the sites I looked at also said it could be exhaust leaks, or a lean condition, sometimes caused by an intake manifold leak.
Old May 3, 2022 | 10:18 PM
greg8453's Avatar
With those codes could be the post cat sensor has a short in the sense line. Something is driving the sensor output low. What does it read? What about a FF?
hunter_darcy
55
Mar 13, 2026 08:36 PM
Nick Calvetti
Drivetrain (Excluding Engine)
Apr 8, 2021 03:36 PM
ChevyGuySS
Jun 4, 2012 03:12 PM
camaro98z28
Jul 11, 2009 08:26 PM
