View Poll Results: Interest in resin 1/25 scale HHR kit???
Yes
97
64.24%
No
5.96%
Maybe, depending on price!
45
29.80%
Voters: 151. You may not vote on this poll
1/25 scale resin HHR kit???
Old Nov 2, 2008 | 01:59 AM
jeffs396's Avatar
Originally Posted by AJochum
It would be nice if the site that makes these resin kits would show a picture of some of them - so we know what we might be getting into.
AJ...here's one example of a kit that's never been produced in plastic...1964 comet station wagon!
http://www.perrysresin.com/
Name:  perry's 1964 comet wagon.jpg
These are basically like a plastic model kit, but different material is used for casting. Uses unique glue and techniques for assembly. Some use current kits for donor parts, some are complete kits...hence the varying prices.
Old Nov 2, 2008 | 02:03 AM
jeffs396's Avatar
Originally Posted by BigMOCats
Panel?
Sure, once the master is done, different versions (panel, SS, or even phantom pickups, convertibles) are possible. Panel would be the easiest, obviously.
Old Nov 2, 2008 | 07:23 AM
hyperv6's Avatar
Please understand these kits for the most part are not for the novice. Be aware but don't be affraid.
They do take some advanced modeling skills. Some more than others but in any case they are usally more difficult than just a regular box built Revell.
I have done a few resin kits and things I have had to do is modify donor chassies wheelbases. fab up interiors, cut window and wheel openings, fill in holes in the resin and make my own window glass.
All of this is not difficult if you know how to do it and most resin kit have little or few instructions. It is not so much a difficulty factor as it is a not knowing how to do it factor on some of these things.
I do not want to scare anyone away on this but I just want them to understand these are not just a stock built kits. Many here have done more far difficult work on their real HHr.
If you have not ever built a resin kit and want to do one of these I am sure the first who have more advanced skills will more than glad to share what they did to help the others here.
Old Nov 2, 2008 | 07:31 AM
bigallis1's Avatar
I'm in for one..................
Old Nov 2, 2008 | 09:06 AM
AJochum's Avatar
So would it come with the plastic windows as a regular model would? Any chrome? Picture is much better than I thought it might. I'd go the the $40 area, but probably not to $90.
Old Nov 2, 2008 | 09:17 AM
photojoed80's Avatar
I'd buy 2 as long as long as they're non panel versions.
Old Nov 2, 2008 | 11:09 AM
hyperv6's Avatar
Most kits do not include chrome but you can use chorme foil for areas needing chrome.
Windows can be made from several things. I even have used he plastic lids form a pie cover from the stores. The HHR glass except for the windshield is mostly flat so it should be easier than most models to make side glass.
Old Nov 2, 2008 | 11:47 AM
Nor-Cal HHR Club's Avatar
It needs to be 1/48 or 1/72 scale (most AC models are this scale), not 1/25.
Almost all model kits include chrome plated plastic parts.
Old Nov 2, 2008 | 02:11 PM
jeffs396's Avatar
Probably 90% of automotive kits are 1/25 scale. As far as chrome, I would build the master with a separate grille...for ease of adding an SS grille if desired, or the stock chrome. Yes, mass produced styrene(plastic) kits come with chrome parts, probably only 50% of resin kits have chrome included...but resin parts are just as easily plated as styrene.
Old Nov 4, 2008 | 05:19 PM
jeffs396's Avatar
Here's a couple more we can relate to...
SSR panel conversion:
Name:  SSR panel resin.jpg
1954 panel:
Name:  1954 panel resin.jpg
