2.2L Power Upgrade Year
Old Apr 2, 2019 | 02:03 PM
fastsuv's Avatar
What year did the 2.2L in the HHRs get the power upgrade (and VVT)?
I looked online and can't seem to find the info. Most websites show the original lower hp and don't mention when the upgrade occurred or what the upgraded hp was.
Thanks
Steve
Old Apr 2, 2019 | 02:09 PM
Cat Man HHR's Avatar
Here you go:
https://en.wikipedia.org/wiki/Chevrolet_HHR
Old Apr 2, 2019 | 02:17 PM
fastsuv's Avatar
Wikipedia mentions in the article that in 2009 VVT was added, but the 2.2L engine power output in the chart shows the same 149hp and 152 lb-ft for 2007 through 2011.
I am sure that they upped the hp when VVT was added to the 2.2L.
Steve
Old Apr 2, 2019 | 02:39 PM
What HP do you think the 2.2 should have ?
Old Apr 2, 2019 | 03:14 PM
fastsuv's Avatar
OK, after some searching using Edmunds Used Car specs, here is the answer:
2008 HHR 2.2L - 149hp@5600 152lb-ft@4200
2009 HHR 2.2L - 155hp@6100 150lb-ft@4800
So the hp peak went up (at a higher rpm), the peak torque went down a little (also at a higher rpm).
Steve
Old Apr 2, 2019 | 03:31 PM
This could be due solely to the rpm measured at and not because the VVT engine is more powerful. (I don't know one way or the other) I'm just pointing out manufacturers always play these "numbers games" without showing all the data. Why? It sells cars.
Old Apr 2, 2019 | 10:35 PM
Ron S's Avatar
My wife says it feels like my 10 has more power then her 09 when she drives mine. They both are VVT, the 09 is a LS and the 10is an LT and both are 2.2.
Old Apr 3, 2019 | 07:28 AM
papa_jo's Avatar
I don't care, I like mine. says 155hp. all I know is I step on the gas pedal and it goes
twistrman
Dec 18, 2010 09:54 AM
Kingfrog
Jun 16, 2008 02:09 AM
da_dad66
2.2L Performance Tech
0
Apr 8, 2008 08:03 PM
