Is the 2.4 worth paying the extra for?
Old Sep 27, 2005 | 04:43 PM
teknobunie's Avatar
Originally Posted by adamlowery
Does it help a car at all to use better octane gas? If so what does it do?
In the owners manual it claims that if you use anything less than 91 with the 2.4l then your acceleration will be slowed and you will hear a knocking noise...
Old Sep 27, 2005 | 06:10 PM
mtbiker-s's Avatar
I've been using 87 octane in my 2.4L and I will admit that recently after I turn of the car, I do hear pinging. Next fill up will be with 91. I'll let you know if the pinging stops.
Old Sep 27, 2005 | 07:28 PM
1BadPig's Avatar
Been using 87 since day 1 and no knocking.
Old Sep 28, 2005 | 02:33 AM
parky's Avatar
Junior Member
I agree 87 octane since day 1 and no pinging, buy my gas at Indian Res with no problems in engine. 2000 plus miles so far!
Old Sep 28, 2005 | 05:42 AM
1BadPig's Avatar
Originally Posted by parky
... buy my gas at Indian Res with no problems in engine.
How much cheaper is that?
Old Sep 28, 2005 | 09:57 AM
mtbiker-s's Avatar
Maybe I'm mistaken, does the pinging sound like little rocks hitting the inside of tin can? Kind of like tick, tick, tick tick, tick after the engine has been turned off a couple of minutes.
Old Sep 28, 2005 | 10:11 AM
teknobunie's Avatar
I don't hear anything after I turn mine off, (I have the 2.4L). Try changing your gas, just too see, it sys that after you run the 91 or higher for a bit it should stop, if not take it to the dealer....but let us know either way, I'm curious on this....
Old Sep 28, 2005 | 11:56 AM
mtbiker-s's Avatar
I think I will do that. I'll try the 91 and see what results I get. I'll be taking a nice 2K road trip next week so I'll definantly experiment with octane levels.
Will post results upon my return
Old Sep 30, 2005 | 03:37 AM
parky's Avatar
Junior Member
Gas at the Indian Reservation is around .25c a gallon cheaper. 87 Octane.
Old Sep 30, 2005 | 03:41 AM
parky's Avatar
Junior Member
Exhaust Cooling Sounds
That possibly is the exhaust system cooling down, mine clicks/ticks after shutting off also. It is no problem, just a hot metal cooling down.
