2006 hhr CRAZY
Old Mar 27, 2023 | 07:54 PM
Plat's Avatar
2006 hhr CRAZY
What is this? Do I need to ground the tcm and take out the fuse box clean and reseat?
whatch the video, just purchased and this happened on the way home.
speedo going to zero sometimes, not shifting, Speedo starts working then trans shifts.
power steering lights up then all this happens.
IMG_1441.MOV
Old Mar 27, 2023 | 07:59 PM
Plat's Avatar
I don’t know why the video won’t load.
File Type: mov
Old Mar 27, 2023 | 09:32 PM
yes.
And check the outside connection from the battery, check the connections to the battery, check the maxi fuse near the battery, make sure all of the fuses and relays in both fuse boxes are firmly seated.
Check if the ignition switch recall has been done, link in my sig.
Old Mar 27, 2023 | 09:43 PM
You could try tightening the 3 or 4 bolts inside the fuse block before you go to the trouble of taking it apart. They need to be tightened more than you think.
Old Mar 28, 2023 | 01:02 AM
PulpFriction's Avatar
Don't attempt to diagnose an electrical problem with an iffy battery. Sometimes, the battery is the entire problem. You can get it load tested at most chain parts stores. Then, charge it and let it sit at least overnight and make sure it's holding 12.6V minimum.
If you buy a new battery, at least you'll have something to show for it. Non-returnable electrical parts you didn't really need, not so much.
Jorgito37
Feb 10, 2026 07:41 PM
7734
Oct 1, 2021 01:36 PM
Travisveit
Jan 11, 2021 04:32 PM
tom franks
Jul 13, 2013 05:45 PM
justamodeler
Jan 5, 2013 02:56 AM
