2006 HHR non starter
As I indicated in your last thread; you are also missing the TransmissionControlModule (1 connector), it lives in front of the ECM (2 connectors).
I’ve merged the 2 threads to avoid confusion and double posts. As I mentioned you can get the ECM online, and here’s the TCM also online. You will need to provide your VIN when you order
https://store.allcomputerresources.c...ol-module.html
I'm thinking that the computers were removed because the car died. I would not spend any money with out knowing the condition of the engine and transmission, unless you intend this to be a "project car".
Posts #6 and #15. Need to find out if the engine is even usable.
I hope you weren't thinking it's just a plug in some missing modules and everything will work again. I notice the air breather assembly being off and looks like it has been for a while. Throttle body is probably trashed being open to the elements.
I hope like Donbrew said that this is a "project car"
