2007: Can cigarette port 12v be tapped to add 2nd port?
Old Jul 11, 2022 | 04:03 PM
Connieb48083's Avatar
No offense taken. I am NOT an expert by any means but do have a basic knowledge. Sometimes terms used are presented differently than what I am familiar with. Yes, I do know that the two slots on tap are sequenced. Your clarification is well taken. I will make sure fuse is in the right slot. Your clarifications basically confirmed what I was thinking. Now I know for sure that fuses don't impact computer. I am a believer in asking the question and not assuming I am correct. It's nice, though, when I'm confirmed. ;-) Everyone who has contributed to this thread has been kind and helpful. I'm happy to know that and will make this site my first contact for questions to come. Thank you!!
Old Jul 11, 2022 | 05:53 PM
YouTube has some good videos about installing extra power outlets.
Old Jul 11, 2022 | 08:09 PM
Hi- Yep! I've seen a few. Thanks for mentioning. I've also stumbled upon a few yahoo's... seems anybody will do a video these days...
Old Jul 16, 2022 | 01:31 PM
Fuse Adapter Install Info
Originally Posted by donbrew
One end of the fuse connects to a "hot" side, the other is the output side, if you connect to the "hot" side you bypass the fuse. The tap you linked needs to be inserted in the right orientation or you defeat the purpose of a fuse.
.NONE of the fuses are controlled by any computer. The computer does not care about fuses, NO programming needed. "Spare" means that the output side is not connected to anything and the hot side is connected to the battery positive.
Please don't be offended: I'm not sure you should be messing with thing electrical, you don't seem have a basic understanding. Maybe you are an expert and I'm wrong.
I decided to insert a utube video I found particularly helpful in explaining what DonBrew was telling me. I hope this helps anyone else that reads this thread and has questions about using an adapter.
. My project is done. I want to note that the interior console fuse block design, and the fuse adapter harness size and orientation, limited which open "spare" RAP slot I could use. I successfully hooked up my salvaged power port, and connected my Garmin GPS power cord to power up when car is started and turns off when door is opened. Best Regards and thanks to each contributor. -Connie
Old Jul 16, 2022 | 04:40 PM
Thanks for the follow up and video !
Old Jul 16, 2022 | 06:10 PM
  #26
PulpFriction's Avatar
So with fuses, size matters, and if you tap it, orientation matter too. Got it.
Old Jan 23, 2024 | 01:57 PM
  #27
sands.autolit's Avatar
Re: The diameter of the in-dash power port vs the rear console power port:
On closer inspection today, the center console power port had 2 pennies lodged inside preventing the use of the port! - Sorry. Never mind! I deleted my "help" question.
And now my tire inflator AND phone can be plugged in now. My apologies for not discovering that earlier.
I hope I didn't damage the 15 amp circuit for the in-dash port because it burned out two 15 amp fuses before I stopped inflating the tire.
Thanks for the quick reply, Oldblue!
I think the 2nd blown fuse turned off the engine at the same time! Is that usually possible? Unless in my haste (it was raining at the time, yesterday) I forgot to turn on the engine that 2nd time? IDK.
Last edited by sands.autolit; Jan 23, 2024 at 05:03 PM. Reason: Console power port had 2 pennies lodged inside preventing use of the port! -Never mind my post!
Old Jan 23, 2024 | 04:34 PM
  #28
The power ports front and rear are the same in my 2007 and my 2011. I’m wondering if you have the smokers option the front would be different then for a cigarette lighter
still my rear ports work with garmin and phone charger even my tire inflation pump works in both front and rear
Old Jan 23, 2024 | 09:13 PM
  #29
The fuse for the dash outlet also supplies the OBD port.
Old Jan 23, 2024 | 09:17 PM
  #30
jimvw's Avatar
Been contemplating adding a 'third' power port behind the dash, I have a Bluetooth adapter, phone charger, and my 2M radio all to be plugged in and it would be nice if they were through the ignition/door switch. The 2m radio does need to be disconnected when I am not driving, a Radio licensing thing where if a non-licensed driver is using a vehicle with a radio installed, it needs to be disabled. Kind of dumb as they won't know how to work it but so be it.
