2009 HHR needs cylinder head replacement
Welcome to the site! The 2008 2.2 head is different from a 2009 as the 09 has VVT and the 2008 doesn’t. So you will need to find a usable 2009 thru 2011 2.2 head.
For instance
https://www.ebay.ca/itm/355392302305...mis&media=COPY
Your local pick a part may have a used head for less $ , a gamble as it may have same issues yours has.
For instance
Unsure what caused it. Car handled like normal. Noticed a burning oil smell so I checked and noticed a quite massive leak. From there the Valve cover gasket has been replaced, as have a few O rings. It’s such a small crack it isn’t really visible, but oil just pours right out of it.
For instance
For instance
Clean it up and weld it yourself
https://www.harborfreight.com/8-piec...ods-44810.html
Can’t hurt to try! The heads already junk, you might just be able to save it!
oceangoer
May 2, 2016 10:15 PM
