Advice on purchase.
Old Mar 10, 2024 | 02:30 PM
PulpFriction's Avatar
Originally Posted by jimvw
I put 16's on for the winter with new snows and it worked well. No problems switching from 17 to 16. Put new tires on the 17's and ran through the sumer and mildest winter ever for Minnesota, Not more than a few inches of snow on the ground a season. Did not notice any issues.
Works for us. Wifey's daily LS gets the LT stock 215/50R17 at 25.46" diameter for Summer, 205/60R16 at 25.69" dia. for Winter, somewhat larger and narrower profile than the stock 215/55R16 at 25.31".
For Summer I was really tempted to go with wider 235/45R17 or even 245/45 R17, which was an option as the aftermarket wheels are 8" wide w/ 35mm offset, but thought better of it because they just weigh more, cost more, and Wifey doesn't care. If it were my daily, it woulda been the 245/45R17's.
Still thinking about leveling it by lowering just the rear a bit. Found some old-stock springs that are supposedly Cobalt SS (not LNF) aftermarkets by Moog. But again, she doesn't care. So far, haven't found the motivation.
Old Apr 13, 2024 | 11:41 AM
oldhhrguy's Avatar
I just looked at a 2011 NC car with 165k on it. Silent on start up, so I don't know if timing set has already been replaced. I talked to my car guy and he'll put a timing set in it for 700 bucks total.
I'd consider that on any high mileage HHR I look at, if it helps anybody else to think about it.
Old Apr 13, 2024 | 12:15 PM
If you’re capable, change the chains yourself, that way you know you torqued the fasteners correctly, and installed the correct parts! You might just be replacing new parts for no reason.
Old Apr 13, 2024 | 12:39 PM
oldhhrguy's Avatar
He's reliable and honest. He'll check it before he does anything to it.
As with any used car, sometimes you get the bear, and sometimes the bear gets you.
I know the 2.2 Ecotec had issues, but I don't know how widespread they are after the new design tensioners were available.
Appreciate the feedback
Old Apr 13, 2024 | 03:50 PM
I don’t know of the 2.2 having issues, I had a 2007 for 10 years , 458,000 miles no big issues
skyline26
Canadian Mid East
Sep 18, 2019 09:59 AM
walkowg
Jul 1, 2013 09:48 AM
Augmented78
Jul 17, 2012 07:08 AM
John H
Jul 13, 2010 03:22 PM
Arly08
Mar 14, 2009 11:09 AM
