After only 12 years,...
Old Jan 6, 2018 | 06:24 PM
Grizzly old man's Avatar
So after 12 years the battery in my HHR has finally given up the ghost.
I don't know why it lasted so long and I worry about how long the one I got from Wally world will last.
I have read right here how others have gone through several batteries and wondered then how mine has lasted so long.
Last winter I did not drive the car for over a month in the cold weather {we have a 2016 Sonic so had no need of the HHR} but when I charged the battery it came around and lasted till the second day of -10 degrees.
When I took the battery out it was frozen solid. I let it thaw for 4 days then connected the charger over night. It did not respond very well.
I could see through the plastic that some of the cells were a bit on the low side but, it is a sealed battery and I don't know where to drill holes to refill the blame thing so a new one was the best bet for me.
Old Jan 6, 2018 | 09:04 PM
gio89kid's Avatar
Ac Delco makes the best oil filters and batteries. IMO
Old Jan 7, 2018 | 10:34 AM
My OEM battery was a sealed unit, the new one I just installed has 6 round discs you can unscrew with a quarter to top up the fluid, I will use distilled water for that.
Old Jan 7, 2018 | 12:19 PM
"Sealed" lead acid battery? Where does the gas vent?
I have seen them that looked like there was no way, but have a plastic cover that pops off if you do it right.
This is after the decal is pulled off.
Old Jan 7, 2018 | 12:55 PM
Mine vents out thru the grey tube in the right by the positive terminal in this picture
I didn’t look under the label, the battery was done, so it went to the battery recycling centre!
Old Jan 7, 2018 | 01:47 PM
Old Jan 7, 2018 | 02:00 PM
That’s like my old battery in my S10.
My HHR battery has a small hole in the same area has that and this barbed 90degree fitting goes into it
Old Jan 7, 2018 | 02:25 PM
If that battery on youtube was a series 90 it would have round vent holes and a plug in one and the posts would be reversed and round.
Lead acid batteries would explode if they were really sealed, "Spill Resistant" would be a better description.
Point was there is a way to top off "sealed" batteries. You just need to know how to do it. Now, we all know how.
Old Jan 16, 2018 | 04:48 AM
papa_jo's Avatar
I sure hope my battery grows up like yours did ,Grizzly old man !!!
Old Jan 17, 2018 | 12:03 AM
Well yeah but it died anyway, guess it did have a pretty long life tho,...
