AGM battery for HHR LT
Old Sep 10, 2019 | 04:29 PM
comandoed's Avatar
Originally Posted by Oldblue
Be careful not to touch the positive cable end touch the negative terminal.
It might be prudent to remove the fuse for the RDO #23 interior fuse panel .
My 2007 or 2011 did not require any scans after battery replaced
Ok. I'll be careful with both.
Old Sep 10, 2019 | 04:43 PM
If the battery has a vent hole it would be wise to install the tube. Some group 47 have the hole.
Old Sep 10, 2019 | 05:25 PM
comandoed's Avatar
About this item
Regulated, AGM sealed valve
DIN code:H5/L2
9-9/16 L 6-7/8 W 7-1/2 H
The height is slightly taller than the std 90(T5) which is 6-7/8
Old Sep 10, 2019 | 07:29 PM
Got a ruler?
Old Sep 10, 2019 | 07:49 PM
comandoed's Avatar
Got a ruler?
Yes. I already measured and saw the difference. What is your point?
Old Sep 10, 2019 | 10:32 PM
My point is multi-fold:
1.) In post #2 RJ stated that he has one in his HHR.
2.) I figured you had looked at a size chart and wanted to know if there was room in the car. Thus the ruler suggestion because cars may differ.
3.) I did not know that your ruler is only capable of measuring solid objects. All of mine can measure empty areas as well. Harbor Freight has a few that can do both if you need one.
There was no sarcasm or snarkiness implied or inferred. No reason to get upset.
Old Sep 11, 2019 | 07:41 AM
comandoed's Avatar
Thank you to all who made positive suggestions and helped me get a better understanding.
I will not return to this thread!
I knew that as soon as this last person got involved he would start with his snide, snarky remarks and brow beating.
No time for that!
Old Sep 11, 2019 | 09:25 AM
Well , I’ll f you don’t like the answers, see ya!
Old Sep 11, 2019 | 12:28 PM
Vinnybagodoughnuts's Avatar
Yeah Don.You are so irritating with all of your advice and knowledge.I think this Forum should stop paying you for your time.
Old Sep 11, 2019 | 12:33 PM
He’s getting paid for this? I don’t think so! People can’t read everything as they hear everything and vise versa.
