Aoogah horn
tpsfoto.....
First....WELCOME to this Forum.
You may wish to use the Search function, to review previous threads and posts on this topic. Here is one......
https://www.chevyhhr.net/forums/show...highlight=horn
"The horn is located just under and behind the left headlight. There are three screws and 5 plastic push plugs you will need to remove from the inner fender well to access it. I think the manual shows you how to change the head lamp bulb, that will get you close enough to see it. It looks like a standard GM horn, should be easy to swap out."
THIS is quoted from one the threads. I have almost asked a question but then found the answer by the search feature of this site. Someone will always give you an answer one way or the other. Enjoy your ride and WELCOME to the site.
You also can just stick you head in various locations under the front of the car and have your spouse (or a friend) blow the horn while they laugh. I would choose the first method myself.
NatCh
May 17, 2012 01:02 PM
