Thanks guys, took all but 5 minutes to do, Works perfectly now. The armrest had a little wiggle but the bolt was super tight, looks to be a spring washer that worn down a bit so I flexed it a little more and installed, seemed to do the trick, I did look for an additional washer but didn't have one with a big enough center hole so just flexed it a bit and it worked.
