Automatic trans.
Old Nov 23, 2009 | 04:36 PM
jay loukakis's Avatar
Automatic trans.
anyone know where a spl. filling nozzle to add new fluid, local shops cannot get one the dealer wants $180.00 to change trans fluid I would rather support a good indepant service shop?
Old Nov 23, 2009 | 05:44 PM
ecl's Avatar
ecl
from what Ive read its a sealed trans and has to go to the dealer to get that done. Im not real sure but thats what understood from other topics on this.
Old Nov 23, 2009 | 06:35 PM
Sno White's Avatar
Checking and topping off the HHR’s Auto Trans fluid is very similar to a Manual Transmission. On a Manual Transmissions there is no fluid dipstick, just like the HHR.
On the HHR there is a check fluid level hole sealed with a bolt on the right side of the Auto Transmission. Also there is a vent hole somewhere on the top of the transmission. I haven’t found this vent/hole yet, but believe it to be on the left side.
According to the FSM the procedure is a bit more complicated than any Manual Transmission I have worked upon. As the engine has to remain running during the whole procedure of removing and replacing the sealing bolts. If not you will loose fluid when you turn off the engine.
Start and warm vehicle, remove vent bolt, remove sealing bolt, check level and add fluid through top vent hole if necessary to bottom of check hole, let excess drain from check hole, replace the bolts and turn off engine – done. Vehicle must be level and there may be some problems with access to the holes as the FSM say to use a lift.
I see no reason for this to be a dealer only procedure. Your service shop may not have done this yet and may not want to try. I found no mention in the FSM as to any special tools needed to add fluid. A pump with hose or a funnel with hose I would imagine would work.
I have a few more years until I will need to change my fluid. In the mean time I will confirm the hole locations when I am doing other work to the vehicle.
Old Nov 23, 2009 | 09:39 PM
IgottaWoody's Avatar
Unless your having problems or have realy high milage there is no reason to consider the fluid changes.....
Old Nov 23, 2009 | 10:38 PM
oneton's Avatar
Do you have over 100,000m on your 06 HHR or are you having a prob. with it?
If no to ? then why are you changing it
Old Nov 23, 2009 | 11:16 PM
^ x 3 ^
Old Nov 24, 2009 | 04:46 PM
Laco's Avatar
Have to wonder why its so complicated to check, add or change that fluid. I mean, how much more would it have cost to put a filler tube with a dipstick in it?
Old Nov 24, 2009 | 06:15 PM
asanti's Avatar
I'm ecstatic that I don't have to touch my tranny fluid for at least 100K miles! Having gone through 3 transmissions in my last car and doing fluid changes every 30-40K miles, let's just say that I'm FINE with not seeing another tranny dipstick for a while!
Later
Allex
Old Nov 24, 2009 | 06:18 PM
pyro panel's Avatar
Former Sponsor
I agree..its synthetic oil..unless u had or have a leak no need for mainenance..got trucks with HUGE mileage..still same trans fluid and rear end..
Old Nov 25, 2009 | 12:27 AM
Thumbs up
I didn't know it was synthetic transaxle juice... And I don't miss checking it either..
Long as it's parking spot in my shop is clean...I'm fine with that..
