Battery on 2008
Old Feb 16, 2023 | 05:14 PM
Lee3333's Avatar
Originally Posted by Nabco
Hi, we are now keeping our 2008 HHR at our second home in NC, the car will sit without starting for 2 to 4 months at a time, was thinking of adding a Master disconnect switch to the negative terminial to eliminate the battery from draining, I look at it today and it looks like the negative terminal cable is attached to a ground next to the battery, thinking It will be just as easy to disconnect that cable as it would be to put a quick disconnect switch on it. Thoughts?
Also, it looks like there is a 50 amp fuse right there too, what is that for.
Thanks
Here's the problem. If you disconnect the battery there is no way to open the trunk to reconnect it. You need to attach a battery pack to the terminal next to the fuse box under the hood, then use the power door locks to unlock the trunk then go to the back of the car and open it
What I am doing is running a cable from the negative battery to a switch then the other side to the same ground bolt the factory cable is attached to. Then I will mount the switch on the panel next to the passenger side window.
nedwob
Sep 1, 2018 11:38 PM
OKIE SS
Jan 26, 2018 11:35 PM
Trex08
Dec 2, 2016 09:57 AM
sadler850
May 16, 2014 07:41 PM
HHR_SS_QC
Oct 10, 2009 05:14 PM
