Battery maintainer
Old Dec 1, 2016 | 09:50 PM
Trex08's Avatar
Battery maintainer
My panel is gonna sit in storage for about 3 months. I just hooked up a maintainer inside the vehicle. Anything wrong with putting clamps on the postive and negative battery terminals. Manual for the maintainer says the ground should clamp to the chassis. Anything else around the battery I should clamp on to?
Old Dec 2, 2016 | 12:43 AM
Attaching to the neg battery post is just fine. Attaching to the chassis is likely advised to keep any resulting sparks away from the battery while attaching the clamp.
Old Dec 2, 2016 | 07:55 AM
You could put it under the hood.
Old Dec 2, 2016 | 09:57 AM
I would follow the manufacturers directions, unless the battery is disconnected at the negative terminal
Tyler Harvey
Nov 28, 2014 04:34 PM
87silver
Maintenance and Upkeep
15
Feb 7, 2011 09:40 PM
longhornss
Feb 27, 2009 01:15 PM
ny5112
Apr 9, 2006 10:05 AM
adamlowery
Nov 18, 2005 02:04 PM
