Best non-ss hhr's?
Old Nov 7, 2021 | 10:37 AM
glassdave's Avatar
Originally Posted by Oldblue
That’s the side window sticker , the glove box sticker will be stuck to the glove box door.
mystery solved either way though, says LT right on top although it doesn't say 2LT it says FLT and 1LT is that because its a Panel?
Old Nov 7, 2021 | 11:07 AM
I believe
FLT is the fleet processing option and 1LT is the trim level
Old Nov 7, 2021 | 11:09 AM
It's a 1LT. The FLT means it was a rental or fleet vehicle.
EDIT: Too slow again!
Old Nov 7, 2021 | 11:13 AM
Yes my 2LT was a fleet rental for Hertz and it has the FLT RPO code but it’s definitely not a panel.
Old Nov 7, 2021 | 01:17 PM
glassdave's Avatar
that makes sense, when i got it it had the remnants of a logo on both sides. Was used for computer service like the geek squad but an independent. Seemed to have been well maintained.
Old Nov 7, 2021 | 08:31 PM
glassdave- Pecking order is as follows:
LS = base
1LT
2LT = most optioned up w/FE3 suspension,
SS
Your lower right of yer glove box tag shows 1LT & FE1 suspension, But LE5 engine, you should have a 2.4L, same engine as my 2LT has.
Last edited by sleeper; Nov 7, 2021 at 09:48 PM. Reason: Make correction. thanks Blue
Old Nov 7, 2021 | 09:00 PM
sleeper , that’s LE5 the 2.4 litre engine
Old Nov 7, 2021 | 09:36 PM
OOops, yep I meant LE5, good catch Blue.
Old Nov 8, 2021 | 01:18 PM
PulpFriction's Avatar
Originally Posted by hhrumadbruh
…and even had the factory mud flaps! …I didn't check for the side steps/running boards
What are the best hhr's in your opinion?
Originally Posted by Lonwane
How about a 2LT with an SS rear beam and TTR sway bar.
I didn’t know you could put mud flaps on the front with the running boards. I had a plain vanilla 2008 with no running boards and always intended to get the nice custom fit flaps, never did it. I always assume they were dealer installed or dealer order and never came factory installed.
I always wondered if the FE5 torsion beam was stiffer than non-SS, and even if the FE1 and FE3 were the same. I can see the popularity of the TTR sway bar, because OEM’s like to build understeer into their cars, but I always hated the idea of adding unnecessary weight to the car, especially unsprung weight. I don’t like big tires for the sake of looks for the same reason.
My ideal non SS could go a couple of ways. My plain vanilla (even painted white) 2008 LS I loved for its pure functional simplicity. The 2.2L didn’t have the complication of VVT yet. Its ONLY option was the electric driver seat, and had I ordered the car, it wouldn’t have had that. The only upgrade would have been the Pioneer Premium speakers. The ebony interior ages best.
The other direction for me would be an AA5 2LT with racks and boards and heated seats in Crystal Claret Tintcoat, hopefully possible without the headroom-robbing sunroof.
Old Nov 8, 2021 | 01:39 PM
The mudflats were factory provided and dealer installed.
