Brake Questions....
Old Sep 10, 2020 | 05:45 PM
Bonez's Avatar
Brake Questions....
I ordered a complete set of Power Stop brakes ( Caliper, Bracket, Rotor, Pads and Pins ) for both front which should be a normal swap out as any other brake job Ive done.... Now my question is this..
I want to flush the entire system as I will be adjusting the rear shoes and e-brake so
(1) Do I Bleed/flush the rear lines before I swap out the new calipers on the fronts?
(2) Do I flush each front as I complete it?
(3) Do I need to flush the rear lines again after completing the caliper swaps on the front? ( Im assuming the rear is separate from the front chamber and wont need to )
If done properly it should be Right Rear, Left Rear then Right front and lastly Left front.... am I correct ?
I will be using the 1 man bottle and hose trick and have read not to push the pedal all the way to the floor......so hopefully no issues when my parts get here, picked up new brake fluid and cleaner today, ready to rock it.
Old Sep 10, 2020 | 06:06 PM
Lonwane's Avatar
Brake bleed sequence is RR, LF, LR, RF.
I know this is contrary to older cars.
You can look this info up if you don't trust me.
Old Sep 10, 2020 | 06:38 PM
^^^ he is right! These are different because of the ABS
did you order the SS 11.6 inch non Brembo kit for the front? New hoses to?
Old Sep 10, 2020 | 11:11 PM
That means the MC is split diagonally.
Old Sep 11, 2020 | 08:39 AM
Bonez's Avatar
I ordered the Power Stop stock replacement, not doing anything fancy with the car.
Old Sep 11, 2020 | 02:27 PM
Bonez's Avatar
Theyre here.... making a day next week to replace everything. Pretty nice stuff here.
Old Sep 11, 2020 | 02:32 PM
Bonez's Avatar
So, should I flush the system with new fluid before installing then just bleed the Calipers after replacing each one ? I think thats the wiser choice imo ?
Old Sep 11, 2020 | 05:21 PM
I would flush it with the old parts in. Don't want to install the new calipers, then flush the old ,dirty fluid thru them.
Old Sep 11, 2020 | 05:23 PM
What FMG said!
Old Sep 11, 2020 | 05:50 PM
Lonwane's Avatar
What Oldblue said
