Brake Questions....
Old Sep 14, 2020 | 08:22 PM
  #31
Originally Posted by tiapetra
Totally your choice.
I'm not going to give you bad advice, have done it numerous times, no issues at all. Use 6 point deep sockets
Frankly if the cylinders have been on there a few years, then there will be enough crud in there that replacements may be prudent anyway.
Again, they are not that expensive. $14.00
Agreed 100%
Old May 30, 2024 | 07:21 PM
  #32
shojay92's Avatar
Originally Posted by Oldblue
^^^ he is right! These are different because of the ABS
did you order the SS 11.6 inch non Brembo kit for the front? New hoses to?
Don how do you adjust the parking brake on an HHR SS with rear disc brakes?
Old May 30, 2024 | 10:17 PM
  #33
By using a brake adjusting cube.
Old May 30, 2024 | 10:41 PM
  #34
shojay92's Avatar
Hey Don thank you for responding, is there anything I need to do with the slack on the e- brake cable after the new pad/rotor install? I am assuming once I push the caliper back, the cable will be too long.
Thank you for your help.
Old May 31, 2024 | 07:57 AM
  #35
See Oldblue's response in the other thread.
slonny
Sep 11, 2020 11:17 PM
m_ridzon
10
Dec 16, 2018 02:09 PM
flamarallenjr
Nov 23, 2018 07:11 AM
Cliffs51
Maintenance and Upkeep
Nov 10, 2018 08:38 PM
andoll83
Apr 1, 2009 07:14 PM
