Cabin Air Filter on a 2006
Old Feb 13, 2008 | 01:21 AM
Cardwiz428's Avatar
Folks,
Guess I'm just missing it. My glovebox is on top. I removed it and ran into more plastic. Didn't see it from the front passenger side. How do I gain access to it?
Old Feb 13, 2008 | 01:26 AM
It's at the very top of the passenger side glove box. You've gotta release the tabs holding the glove box door on to drop the door, and then there are three clips that hold the filter in place (not that it needs them with how snug it fits in).
Here's a couple of pics to help you find it........
Originally Posted by jx3
Here's what I first saw when I opened the filter door......
And as it came out
Hopefully your's doesn't look like mine did.
Old Feb 13, 2008 | 04:06 AM
quest51210's Avatar
how often does this need replacing?
Old Feb 13, 2008 | 06:12 AM
Old Lar's Avatar
Depending on your driving conditions, I believe the owners manual say 50,000 miles. More frequently if driving in dusty areas.
Old Feb 13, 2008 | 06:48 AM
an08HHR's Avatar
Welcome. You have two glove boxes. One on the top center of the dash which is the one you are describing and one in front of the passenger on the lower section of the dash at knee height
Old Feb 13, 2008 | 06:57 AM
-md- HHR's Avatar
I change mine every year, and its ALWAYS dirty.
Old Feb 13, 2008 | 07:00 AM
It's listed in the owner's manual under "Maintenance II" schedule. When you change the oil, this filter should be changed as well (i.e......Once a year or about every 10K). And as Old Lar said.... maybe more often in dustier conditions.
Old Feb 13, 2008 | 07:19 AM
karen1953's Avatar
I change mine every 5,000 miles, just like the oil, oil filter, and rotate the tires. Do all in the same day.
Old Feb 13, 2008 | 08:02 AM
Smoke Wagon's Avatar
My 06 came with a new cabin air filter. When I finally do my first oil change, I'll check my filter to see how it held up during my normal driving conditions.
I dont live in a dusty climate at all...but i do drive ALOT...so I'll be sure to change it as soon as it needs it.
remember...if your cabin filter is dirty...your engine's air filter is probably DIRTIER, and more important.
Old Feb 13, 2008 | 08:40 AM
wingfeather's Avatar
They need to make these things easier to check (across the board, not just Chevy). You'd be surprised the labor involved in simply checking to see if it's dirty. Oh, I think I answered my own question...
