Can I leave an AC adapter plugged in 24/7 as long as it's not charging anything?
Old Apr 7, 2018 | 05:22 PM
Jpak88's Avatar
I know that power is constantly supplied to the thing, but of I just have the adapter itself plugged in with the car off, nothing charging off of it, will that drain the battery too?
Old Apr 7, 2018 | 06:44 PM
It’s been known to happen, plus the adapter can overheat.
Old Apr 8, 2018 | 01:36 PM
Depends on the adapter.
An inverter does not draw if it is turned off, but does any time it is turned on, with or without a load, since it is producing heat energy if not DC energy. If it has no on/off switch it is drawing when plugged in.
A simple 12VDC/5VDC doesn't. That is just a resistor on 1 leg of the circuit. A more complicated circuit would draw.
Old Apr 14, 2018 | 03:04 PM
UWZerokoolX's Avatar
I leave my phone charger plugged in over night but it does not drain the battery. If that is what you are referring to, I would recommend having your battery tested.
Old Apr 14, 2018 | 03:08 PM
Agree, I leave my phone charger plugged in at all times. Sometimes the phone is plugged in, usually not. I've never had any problem.
An AC adapter, though, may be a completely different thing.
Old Apr 14, 2018 | 03:33 PM
ooohhhhh my bad. Missed the "AC" adapter. When I was truck driving, I always unplugged mine because it did drain the battery on my semi after a few days because it is constantly converting DC power into AC power at the ready, it does not necessarily "store" that power and hold it like a battery would. So yes, I would definently unplug it while the vehicle is not running.
Old Apr 14, 2018 | 04:10 PM
If it gets hot it is using energy. Inverters have heat sinks for a reason.
cannuck
Sep 8, 2019 09:53 PM
junker
Jul 26, 2016 10:16 AM
hhrumadbruh
0
Nov 9, 2013 10:51 PM
HillsdaleHHR
Apr 9, 2007 11:30 AM
