Car will not start after battery removal.
Old Jan 23, 2025 | 10:28 PM
jd_boggs@yahoo.com's Avatar
My 2010 HHR will not start after removing battery from circuit for several hours. I have read that in some model years car has to be towed to dealer for reprogramming etc.
Car ran fine until I got p1142 code I then replaced the cam sensor but still got the same code back a day later. To confirm the 3 wires to cam sensor were correct I ohmed out the circuit but had to remove both ECU connectors to find the wires etc. this took a few hours. The result is that the ECU was isolated for several hours without power and I got comm errors when I insert the code reader to find the new problem... What caused this situation? What advice do you have for me? Any help will be appreciated thanks.
OK, found my problem that I was getting communication error codes when trying to read OBD codes. I did NOT have the tranmission plug all the way locked in. Once I corrected that I could read the codes but got "BRAKE" light is left on. Will deal with that later. But thank you all for your ideas. Someone posted to check for bent pins that's what lead me to the unlocked connector..... my bad
Last edited by jd_boggs@yahoo.com; Jan 24, 2025 at 01:30 PM. Reason: found my problem
Old Jan 24, 2025 | 07:13 AM
Check your ECM connections for dirt and bent pins.tighten the 4 bolts in the under hood fuse box, I’ve had the battery disconnected at the negative terminal for a few days waiting for parts, didn’t need a reflash , it started right up.
Old Jan 24, 2025 | 08:20 AM
I can't find P1142. What is the definition you see? I see some VW references about the crank sensor.
If it cranks but not start:
check the timing chain.
If it does not crank:
My money is on a broken battery connector, making for a loose connection. Maybe the fuse near the ground blew, that is power for the BCM.
Farcebook is full of BS, the only thing that might need reprogramming is the RCDLR if it was a 2008.
Old Jan 24, 2025 | 08:45 AM
I found this generic code reference, nothing about cam position sensor
https://www.obd-data.com/p1142.html
Old Jan 24, 2025 | 08:52 AM
So, my guess is somebody forgot to plug the MAF back in. Or, not fully.
Check the ECM connector pins for bent or pushed out the back.
Old Jan 24, 2025 | 09:02 AM
P1142 for GM it directly call out cam sensor on the left side of engine. For Ford it calls out several other places....
Old Jan 24, 2025 | 09:03 AM
MAF is plugged in ...
Old Jan 24, 2025 | 09:05 AM
MAF is plugged in....
Old Jan 24, 2025 | 09:17 AM
No
A Google search for GM code P1142 shows it is for a HO2 sensor problem.
And a search of the trouble codes monitored by the HHR programming does not list a P1142 code in its system.
You should try another code reader.
Old Jan 24, 2025 | 09:21 AM
When I GoOgle "p1142 gm specific code" I find references to #2 O2 sensor, with possible reasons faulty fuel injector, a problem with the air/fuel mixture, or a malfunctioning oxygen sensor itself. Nothing about cam sensors.
A GM specific code "P1142" indicates an issue with the oxygen sensor circuit on Bank 1, Sensor 2, specifically that the mean voltage level is reading "rich" (meaning the engine is burning too much fuel) based on the sensor data.
Breakdown of the code:
  • P: Indicates a powertrain related diagnostic trouble code.
  • 1142: Specific code related to the oxygen sensor circuit on Bank 1, Sensor 2.
What it means:
  • The oxygen sensor on Bank 1, Sensor 2 is detecting a higher than normal amount of oxygen in the exhaust, which suggests the engine is running rich.
  • This could be caused by issues like a faulty fuel injector, a problem with the air/fuel mixture, or a malfunctioning oxygen sensor itself.
