Clutch go down, don't engage and liking on reservoir brake
Old Aug 6, 2022 | 05:32 PM
  #51
If you look at post #31 the clutch line hose has the clip. Have a close look at the line,
Old Aug 6, 2022 | 05:43 PM
  #52
You sure? Looks like it's in the master cylinder. I just see the groove in the metal on the end of the hose. And another clip in the slave cylinder.
Old Aug 6, 2022 | 09:30 PM
  #53
tomasorta's Avatar
Thanks so much, I already bought the master cylinder(yes include the retainer clip) online in rock auto. I just need to disconnect from the clutch pedal and twist to come off.
Thanks so much for your support guys!!
Old Aug 7, 2022 | 06:47 AM
  #54
Does the new master cylinder eliminate the crusty rusty piece? Or is that part of the clutch line?
Old Aug 7, 2022 | 10:02 AM
  #55
That's the line. Post #41 shows it pretty clear.
Old Aug 7, 2022 | 10:26 AM
  #56
The red stuff is probably "Gorilla Glue"tm.
Old Aug 7, 2022 | 10:41 AM
  #57
I see it now the photo in post #31 shows the line reversed, the higher end is the slave cylinder end . Sorry my glasses were very dirty! I’ve cleaned them now!
Old Aug 12, 2022 | 11:13 PM
  #58
tomasorta's Avatar
hello guys today I get the new master clutch cylinder and I replace is ok I tested put new brake fluid and I didn't see any leaking but the clutch going flexible, so I need to bleed the clutch now, but I never did that before, I bleed the brake before but never the clutch, Ihave the vaccumm for bleeding brake, so somebody has the experience bleeding the clutch?
thanks in advance
Old Aug 13, 2022 | 07:42 AM
  #59
Same principle, use the vacuum to bleed the clutch
Old Aug 13, 2022 | 11:46 AM
  #60
tomasorta's Avatar
thanks oldblue but where is the feeting/valve for connect the vacuum?
thanks
