Cobalt SS Lowering rear spring thoughts...
Old May 21, 2015 | 04:41 PM
Silverfox's Avatar
Originally Posted by Oldblue
Cool, don't forget to remove the bolts for the brake hoses before you remove the lower shock bolts.
That's right..... Thanks for the reminder....
SF
Old May 21, 2015 | 05:00 PM
I just had a friend stop by and he had a shop install his springs, he was complaining of a spongy brake pedal , the hose clips were bent and the left rear hose was wet.
Old May 23, 2015 | 10:30 PM
prod's Avatar
Originally Posted by Silverfox
The other confusing option is the KYB shocks 349043 Excel G.
Many like them but there HHR application is one shock for both FE-1 and FE-3.
Not sure what that means for a reliable performance comparison.
Silverfox
The gm FE3 shocks are gas charged, the FE1 are not. I think the excel-g is gas, so should give performance closer to the FE3.
Old May 26, 2015 | 08:07 PM
HHRLEY's Avatar
I'd recommend you work a deal with Oldblue on the Canucks. They give a good stance and ride nice. I waited 3 months this winter for them to run another batch, it was worth the wait. I have rear TC on my other HHR and I prefer the Canucks. Good price too.
Before:
After:
Old May 27, 2015 | 08:08 AM
I just have the two rear springs not a full set!
Old May 27, 2015 | 02:49 PM
Silverfox's Avatar
HHRLEY,
Thanks for that info...
Your panel sits nice.
Is your other HHR with the TC springs a 1LT or 2LT.
From your photo's it looks like the red panel is a 2LT.
Are the Canuk springs wound differently then stock GM FE-1 and FE-3 springs?
With only 14,000 miles I am primarily going to keep this 1LT stock except for Lowering springs, Possible FE-3 Rear or KYB shocks with a TTR rear sway bar optional if needed and a Trifecta tune later on.
Damn I hate to mess with the 2.4L in this car as I just did the check for mileage and
on a 300 mile hiway trip over 4 passes and air conditioning on half the time, I got 34 mpg with 87 Octane fuel. I kept my speed to about 60 most of the way.
Ride quality and Noise level is of high importance for just a daily driver.
I am also thinking of Pirelli Cinturato P7 All Season Plus 205/60R/16 tires on my stock 16" 5 spoke steel wheels.
I put the 205/60R/16's ( Not Pirelli's) on my last 2011 2LT and left the stock FE-3 suspension alone.
Ran them @ 31lbs. cold and found a noticeable improvement in ride quality without much difference in handling unless your driving very aggressively. I didn't try increasing the air pressures to see if it made any difference in handling as I was not concerned about that issue.
Tire diameters are close enough to the stock 215/55R/16's so as to not cause any real issues.
Bottom line do you think the Canuck springs ride softer or ??? then the TC springs
assuming both your HHR's are 2LT's.
One other thing I notice on this 2010 over all the other 7 HHR's I have owned is the stance it has from the factory. This one seems to look higher in the rear but the front to rear measurement does not bear that out. 1 3/8" difference is all .. completely stock.
The only thing I can think of is the front is sitting slightly lower then the last HHR's.
I have no way to recheck that as all prior cars have been sold.
Technically the SS/SC spring with the SC bumper still intrigues me as I am after a more comfortable ride when all is said and done.
SF
sinabu
Mar 26, 2015 06:58 AM
gangster moblie
7
Jan 5, 2011 09:21 PM
Rooster
7
May 6, 2010 10:56 PM
capp002
Apr 28, 2009 05:31 AM
06Daytona
12
Apr 26, 2009 10:27 AM
