code P0449 HHR 2006 Evaporative Emission Control System
Old Aug 21, 2022 | 07:54 PM
tomasorta's Avatar
Hello I have issues with this code P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit, somebody had this code in his vehicle before?
thanks
Old Aug 21, 2022 | 08:12 PM
Yes. Why do you ask?
Old Aug 22, 2022 | 03:48 AM
PulpFriction's Avatar
I think it’s probably an open or short in the solenoid part of the evap vent solenoid or a corroded connector or bad wiring.
Old Aug 22, 2022 | 05:55 AM
Yes, I have had that code. Test the valve under the hood, it should be closed and you should not be able to blow air through it.
Old Aug 22, 2022 | 07:54 AM
Assuming you are asking for help not just statistics:
P0449 is the VENT valve near the gas tank (P0443 is the PURGE valve). Start with the fuse labelled "cnstr vent" #64 under hood. Then proceed to the connector at the vent solenoid. Then look for frayed or broken wires between the connector and the engine compartment . Last, replace the EVAP vent valve.
There might be a pigtail/adapter/splice between the harness and the valve.
Old Aug 22, 2022 | 08:27 AM
https://www.obd-codes.com/p0449
Don’t forget to look at that new valve , doe’s it have a new seal? Don’t throw out the old valve until you confirm that, you might have to reuse the old one.
https://www.chevyhhr.net/forums/how-...acement-44780/
Old Oct 1, 2022 | 03:04 AM
tomasorta's Avatar
Thanks oldblue, I replace I disconnected the ld one, was super dirty inside a lot of peace rock or something inside, so I replace for other one and now the code is gone...
Old Oct 1, 2022 | 07:55 AM
Awesome!! Thanks for your follow up!
shojay92
Dec 4, 2021 03:02 PM
B.Diggity
11
Jun 8, 2013 03:45 PM
otiscohillbilly
Feb 28, 2013 03:55 PM
Heritage High Roof
Apr 21, 2012 05:02 PM
Diskokid
Jan 2, 2009 10:19 AM
