Compatible 2.2L engines for '07 HHR LT
Old Sep 12, 2017 | 12:02 PM
  #31
928HHR's Avatar
Originally Posted by 928HHR
There are 2 things left of the coil pack on the valve cover. Mine does not have it. Would it still work?
the engine appears to be VVT and mine does not have that info word on the valve cover.
Old Sep 12, 2017 | 12:17 PM
  #32
Then it will not work as a swap. You will need an early 2007 engine as the later ones were VVT - and not compatible.
Old Sep 12, 2017 | 12:42 PM
  #33
These things? The black and grey solenoids, then it's a 2.4 or an 09 2.2
Per
GM Inside News Forum
Old Sep 12, 2017 | 12:48 PM
  #34
The coils should be separate
Not a coil pack like this
This one is a VVT
Old Nov 22, 2017 | 08:28 AM
  #35
928HHR's Avatar
So an update again. (private life got in the way of working on vehicle.)
I am looking around for an engine again and found some in Phoenix. I am far north Arizona and last time I went down to Phoenix the motor was in the car still and it was the wrong one! (tsk!) Judging by my engine I am looking for one that's not equipped with the ACV, correct me if I'm wrong. I really need to get his car up and running soon. And if you could can you tell me what other engines from other vehicles are a direct replacement for mine? I tried looking at that list you provided but a little idea on how to read it.
And if it helps - VIN # of my HHR: 3GNDA23DX7S585396.
Thanks!
Old Nov 22, 2017 | 09:38 AM
  #36
The easiest thing is to call your local junk yard, they have computerized application data. Some can get one if they don't have one in stock.
You are looking for a L61 2.2L non-VVT, 2007-2008 HHR. Maybe 2007-2008 Cobalt, Saturn Ion, some of those had a power steering pump gear on the cam.
Old Nov 22, 2017 | 09:47 AM
  #37
928HHR's Avatar
That's what I did the first time I went to Phoenix and I drove there cash in hand only to come back with an empty truck bed. Wasted my time. I may go there again today. To a different salvage yard though.
Towerdawgdonnie
2.2L Performance Tech
23
Mar 23, 2017 09:58 AM
mdp636
Dec 26, 2013 09:32 AM
hhrfreek
2.4L Performance Tech
Feb 1, 2011 06:52 PM
aven11
Jan 26, 2011 06:49 AM
knelson1969
Nov 14, 2010 07:34 PM
