Complete Exhaust systems?
Where can I order a complete Manifold back plug n play exhaust system ( don't need manifold ) it should consist of the flex pipe, cat, all piping, muffler and tailpipe? Would love a solid welded system but a clamped one is also fine ( I can have welded ) seems most of where I look is buying a puzzle piece by piece? Not looking for anything expensive.
Gibson makes a great stainless cat back and ZZP has the stainless catted downpipe.... But, that may not fit your "Not looking for anything expensive." bit.
I can vouch for the quality of the system though... |
ZZP has cat and non cat downpipes
there are mandrill bent catted down pipes , single and dual cat in EBay, the single cat version woke up the 2.2 in Oldblue, the tubing is 2” and no crumpled bents smooths out the flow. then the cat back that greybeard has mentioned Gibson is a good brand |
Originally Posted by Oldblue
(Post 890267)
there are mandrill bent catted down pipes , single and dual cat in EBay, the single cat version woke up the 2.2 in Oldblue, the tubing is 2” and no crumpled bents smooths out the flow. then the cat back has mentioned Gibson is a good brand I know "cheap" is just a figure of speech.... just more towards that end of the scale is what I meant.... but sometimes we just have to bend a little and give in or maybe its the shiny gleam that attracts us to get it anyways LOL me, its under the car, no one will see it unless on a lift or rolled in a ditch so I aint worried about being pretty LOL |
My 2007 didn’t have the two cat down pipe from the factory, that started in 2008 for the 2.2.
some members gut the second cat to improve flow. So, if you’re not from California or New York , then get the single cat version. |
(Post 890273)
Then ZZP single cat would be a good choice
No speed shops in Missouri? I would ask about muffler shops but, they don't "roll your own" much anymore.
I went with the ZZP and Gibson stainless system because I don't ever want do it again.... Welds are top notch, material is too, Uses all the original hanger locations, bends are excellent. Instead of the U-bolt clamps Gibson supplies, I would suggest those strap clamps that are available.
I went with Gibson on my truck too... Good stuff. |
Originally Posted by donbrew
(Post 890289)
