Coolant temperature
Old 02-05-2009, 08:49 AM
RkyMtnHHR's Avatar
Most times mine is in the 190-200 range. The coolant/water in the radiator will start to vaporize around 250-260.
RkyMtnHHR is offline
Old 02-05-2009, 11:17 AM
Old Lar's Avatar
Originally Posted by kornellred
I would like to see a more sensitive, functional analog temperature gauge in my HHR, so that I don't have to constantly scroll through the DIC readout to check engine temp. My gauge just sits on the fourth mark (right below half-way) and never moves. I have never seen a picture of an HHR's instrument cluster where the needle on the temp gauge is anywhere but on the fourth mark. (if it's up to operating temperature, of course)
Just leave the DIC on the temp setting if you have concerns. I usually leave my DIC on the MPG setting. The temp gauge won't show much difference between 195-212, all within normal operating temperatures.
Old Lar is offline
Old 02-05-2009, 11:23 AM
GRUMPEE's Avatar
What he said. I set the DIC to the temp setting when I'm concerned about overheating especially when going up mountain passes w/ passengers and cargo. Otherwise it's set to MPG most of the time
GRUMPEE is offline
Old 05-11-2011, 03:02 PM
molecule's Avatar
Glad I found this tread only had my hhr since thursday , and have seen normal driving and in traffic temp. of 190-208 which seemed high to me from my other vehicles.Feel better now
molecule is offline
Old 05-11-2011, 08:37 PM
Imagine my surprise when I found out that "normal" operating temp is around 196F, but the tstat is 180F! Go figure. But if you look at it, the tstat is on the bottom side of the radiator, not the top like older cars; so the tstat is to keep the temp "high" enough, not "low" enough. Did I make sense or logic?
donbrew is offline
Old 05-11-2011, 10:53 PM
TomsHHR's Avatar
Location: Superior, WI - Over the Hill Warranty Club member
My HHR temp needle points between 2 lines, this one and that one!! |^|
Now my 2009 silverado has a 185 and the temp runs 210 all the time when warmed up.
The 5.3 on my Bucket has not completely warmed up yet. After 20 minutes the bottom of the radiator was still cool 100 degrees when read with a thermal gun with 185 at the thermostat elbow.
TomsHHR is offline
Old 04-27-2019, 02:45 PM
Robert Guenther's Avatar
What temp should my HHR be at?
Robert Guenther is offline
Old 04-27-2019, 04:28 PM
About 190F. It will vary from 180F to 219F.
donbrew is offline
gio89kid
Maintenance and Upkeep
25
03-15-2015 12:15 PM
JamesCardoza
08-16-2013 02:19 PM
HHR01844
01-07-2010 11:49 AM
andoll83
12-07-2009 10:14 AM
Dredd9799
05-17-2009 12:51 AM
Quick Reply: Coolant temperature
