Decoding the VIN
and the answer I found
"Look in the glove box on the inside of the "door" there will be a placard that says "SERVICE PARTS IDENTIFICATION". It contains info on how the vehicle was built. You will be looking for FE3 That is the code for the Sport Suspension System that is ONLY available on the 2LT.
If you see FE1 then it has standard suspension and is NOT a 2LT.
Good Luck" from DAVE C
Here is the list of factory options that may help you determine the model...
http://www.chevrolet.com/hhr/features/
Regards....
Regards....
