Difference between 06 and 09 HHR
Old Nov 30, 2015 | 07:15 PM
LTHHR's Avatar
Is there a difference in the body as far as the running boards. Will running boards fit a 2009 from a 2007?
Old Nov 30, 2015 | 08:06 PM
Bodies were all the same.
Running boards will interswap. Just make sure you get all the mounting hardware from the donor car if you're putting them on one without them.
Old Nov 30, 2015 | 08:16 PM
LTHHR's Avatar
Thank you for the help Sir.
Old Nov 30, 2015 | 09:14 PM
Trex08's Avatar
Hhrs look like absolute doodoo without them.
Old Dec 1, 2015 | 06:15 PM
There are the LS/LT running boards with the black treads and the smooth SS more of a skirt then a running board the 06 to 11 model years are all compatible!
Old Dec 1, 2015 | 06:59 PM
Oldblue. I think you meant "treads".
Old Dec 1, 2015 | 07:10 PM
I did, darned auto spell!!
Old Dec 3, 2015 | 02:27 PM
rhomanski's Avatar
Mine doesn't have running boards and I was kind of glad of that. I put a set on my 85 Dodge panel minivan and they would sing at highway speeds and give the thing lift. I could feel the suspension lifting the faster I went. Do the GM ones do that to the HHR?
Old Dec 3, 2015 | 03:52 PM
No , no lift they don't protrude out that far! Like the AMC Matador!
AMC Matador coupe | Bond Lifestyle
Old Dec 3, 2015 | 05:28 PM
DwRed2LT's Avatar
lmao . . . . Oldblue
