Do I run my A/C on "fresh" or "recirc"?
Old Aug 24, 2014 | 08:19 AM
Originally Posted by Ron S
The only times I run the A/C on recirculate is when I spot a dead skunk in the road or VDOT is kicking up a lot of dust when working on the road.
Down here in "Humid Country" the forecast for today is 96,97 w/ heat index of 110-112.
IF, I go out in the car today, you can bet I'll need that little bit of extra cooling that the recirculation setting will give.
Old Aug 25, 2014 | 03:24 AM
2oodoor's Avatar
Originally Posted by 843de
Don't forget to run the blower for a few minutes with the A/C off before you park your HHR on a humid day. Doing that helps prevent mold growth on the evaporator, and the possibility of having "stinky" A/C.
It's a trick we use here in the Southland where mold growth in automotive HVAC systems is widespread.
Omg thats so anal ...bbbut youre right
(Wonder who how many actually does that)
Old Aug 25, 2014 | 06:26 AM
db/sb's Avatar
I do that (when I think about it) but I learned of it during my HVAC/MVAC training.
Old Aug 25, 2014 | 07:48 AM
manicrodder's Avatar
Recirculating air in winter can fog your windows.
Old Aug 25, 2014 | 09:32 AM
jay loukakis's Avatar
If you smoke in the car set to recir. the smoke is terrible.
Old Aug 25, 2014 | 10:18 AM
db/sb's Avatar
Rant on: Smoking in any vehicle under any circumstances is terrible...../Rant off.
Old Sep 11, 2014 | 07:50 PM
JAN67's Avatar
I do! I think I finally have my wife trained to do this, too.
Old Sep 11, 2014 | 09:53 PM
Benjiwah's Avatar
There is an important reason to use the fresh air mode. The outside air is going to be more oxygen rich, which helps to keep the driver more alert. This is why the majority of cars default back to outside air rather than recirculate.
Old Sep 16, 2014 | 06:22 PM
Laco's Avatar
Originally Posted by jimfet
This is one of my pet peeves of this car. The air runs cooler on recirculate, so I run it there. But when you cut your car off and cut it back on, it defaults back to fresh air. I would like for it to stay where I put it.
All cars that I have had default to fresh air when started, unless they have climate control, then it will switch to recirculate automatically based on the the temperature difference between the thermostat setting and the actual cabin air temperature.
Old Sep 17, 2014 | 09:44 AM
My Owners Manual tells me that the A/C compressor runs when in recirc mode with no indicator light.
That must be why the air is cooler!
geg
Nov 25, 2020 12:52 AM
kayakjax
21
Sep 29, 2011 09:11 PM
stephenm
Sep 1, 2011 11:27 PM
misterjensen
Aug 21, 2007 11:12 AM
