Door Poppers - any adjustment ? HHR Panel
Old Nov 21, 2018 | 06:38 PM
dougcjohn's Avatar
Recently acquired a 2008 HHR Panel LT, enjoying it a lot and all this forums feed back & information.
I notice often the Drv Side Door Popper doesn't always push the door out far enough to release the latch. Often requires 2nd or 3rd press of Openers (remote or dash button).
Is there any adjustment to the Popper, or is this a sign it's needing replaced? I did spray white lithium grease on the latches & hinges without any improvement.
Old Nov 21, 2018 | 07:46 PM
letterman7's Avatar
Both my rear doors do that. It'll take two taps on the remote or dash, or sometimes if I just hold the button they'll open all the way. I think others have the same "issue", though I suspect it may be inherent as a safety thing - just in case someone inadvertently hits the button while the car is underway. If you're parked on a slight incline where the car is tilted to one side and try to open the uphill side, that, too, won't quite release the latch all the way. I've had to pull the door while tapping my remote button in some instances.
Old Nov 21, 2018 | 07:47 PM
Read post 16 - https://www.chevyhhr.net/forums/prob...p-59738/page2/
Old Nov 21, 2018 | 07:51 PM
No it's not a safety issue - read post 14 in the above link.
And post 3 at the start of that link.
Old Nov 21, 2018 | 08:26 PM
dougcjohn's Avatar
Originally Posted by whopper
I'll need to check if the washer noted in the TSB was performed.
Interesting, that does what?... spaces the door link back a little so it has more free moment before the link contacts the friction mount?
Alignment of striker... Checked how with Popper... Hold manual handle "open" and test door latch fit to striker or is there a better way?
It all looks clean and not gummy, but the "gummy" comment may be a possible, I've noticed it's worse on cold mornings.
Then again, some times it pops the door open nicely... parked in same place each time: Garage stall or Office Parking stall.
It's not consistent.
Along a similar subject, a persistent Door Link Noise on opening the door. The Driver's Door most prominent but other doors too.... when opening, it makes a creak sound, like 2-3 separate creaks as door is opened. I applied white lithium grease into hinges and link without any noticeable change in tone of creak sound. Actually opening feels very smooth, door latches easy, opens smooth without drag.... just makes a creaking noise.
Is there a component in the Link piece... spring friction plate or something that wears and needs replaced?
Old Nov 21, 2018 | 08:50 PM
letterman7's Avatar
I do remember reading that at one point. I'll have to try the washer thing.
Old Nov 21, 2018 | 08:53 PM
kustom's Avatar
good info my doors stick going to try adding a washer thanks
Old Nov 21, 2018 | 09:30 PM
The other thing is to make sure the gasket is clean, some people like to put rubber presevative stuff on all the gaskets and it gets sticky.
Old Nov 21, 2018 | 10:37 PM
And make sure your fob battery is up to snuff.
Old Nov 22, 2018 | 12:17 AM
dougcjohn's Avatar
To follow up post #5 question...
what does the 2mm washer do or address to correct?
If 2mm is good, is 4mm better?
Any thoughts on the door link creaks?
