HHR Panel Rear Door Popper problem...HELP!!
Old Dec 18, 2017 | 08:26 PM
There once was a lonely draftsman....
What do you mean?
Old Dec 18, 2017 | 08:28 PM
What do you mean?
Ah, yes, the Legend of the lonely draftsman... hasn't been told since ages past...
Old Dec 18, 2017 | 08:40 PM
Milton Grimes's Avatar
What do you mean?
The legend shows what all the symbols are. It's been more than a decade since my last electronics class and some of those symbols don't look familiar.
Old Dec 18, 2017 | 09:02 PM
They are all labelled. Most of the lines are wires. Boxes are components.
Here is some more, if you have a Tech2 or similar there are some procedures and codes.
Old Apr 8, 2018 | 09:12 PM
housewiz's Avatar
Having the same issue with my '10 Panel - dash buttons create release sound however I too have to reach thru open front doors, pull door handles, then push door to open.
Old Apr 9, 2018 | 05:32 AM
Is this new behavior?
Have you read the Owner Manual? "To use the buttons on the instrument panel, the driver
side door must be unlocked."
Can you observe the popper functioning?
Make sure the latch is aligned no drag.
Door gaskets routinely get "detailed" with shine that turns sticky.
The other thing is the TSB on the subject 09-08-64-001a that says to add a washer mounting the door check link.
ericbrustad
May 20, 2016 09:12 PM
my first pannel
Dec 5, 2013 03:23 PM
TJ_HOOKER
Jun 26, 2013 07:24 PM
working on it
Jan 11, 2013 05:04 PM
trucky
Aug 19, 2011 11:47 PM
