Doors won't unlock when put in park
Old Jan 16, 2018 | 03:34 AM
shojay92's Avatar
Hello everyone:) I am having problems yet again with my 2006 HHR. This is what it is doing: I push the unlock button on the keyfob and the doors don't unlock. The headlights and the rest of the lights all light up but the doors don't unlock. Also when I go to push the lock button on the fob the lights all flash but the doors don't lock. When I get in the car to start it, I pull it out of park, the doors no longer lock. And the opposite when I put the car in park the doors don't unlock. I have no choice but to manually push the plungers up and down. Also, the drivers side power lock button on the door no longer illuminates. I checked fuse #26 under the hood and it works fine. I am scratching my head on this one. Could some body please help? I love my little buddy HHR. And I don't want to part with it.
Old Jan 16, 2018 | 07:45 AM
First off try a battery lobotomy, disconnect the negative cable at the battery for 30 minutes.
This will reset the computers and the locks.
Also replace the battery in the key fob, it’s a CR2032.
Old Jan 16, 2018 | 07:53 AM
Cat Man HHR's Avatar
I would look into replacing the rubber/carbon button part of the fob and also wipe the grid inside it with isopropyl alcohol being it's a 2006 key fob too.
Old Jan 16, 2018 | 08:36 AM
Correct it’s a relay in postion #26 under the hood
The locks fuse is #26 on the BCM fuse panel under the console.
#26 on the BCM. Does the remote start work?
Old Jan 16, 2018 | 12:06 PM
Here's something that might help
Chevrolet HHR (2005 -2011) ? fuse box diagram | Auto Genius
Old Jan 16, 2018 | 12:31 PM
So my pictures weren’t clear ? BCM fuse panel lid diagram
Old Feb 7, 2018 | 10:01 PM
shojay92's Avatar
Thank you all for your help:) it seemed to have fixed itself
Hewbie
Jul 7, 2016 03:10 PM
LEN
Maintenance and Upkeep
Nov 7, 2015 02:14 AM
Goldie6175
Apr 25, 2014 06:37 PM
oneton
Mar 14, 2012 02:02 PM
