Evap Pressure question
Old Nov 19, 2016 | 07:52 PM
webpirate's Avatar
I was playing with my torque app today and I notices that my evap pressure jumps over the place from about -600pa to -30pa. Is this normal behavior?
Old Nov 19, 2016 | 08:29 PM
Yes.
Do you understand what the numbers mean?
Old Nov 20, 2016 | 08:39 AM
webpirate's Avatar
only that the pressure in the gas tank is changing?
Old Nov 20, 2016 | 08:51 AM
The gas tank is a sealed system, the gas is pulled out of the tank by the pump. What happens to the air pressure in that case?
The EVAP vent valve lets some air into the tank periodically.
The EVAP purge valve lets gas fumes into the combustion chamber at a variable rate. You can monitor the duty cycle of the purge valve and probably notice a correlation between it and the PSI change.
Old Nov 20, 2016 | 09:20 AM
webpirate's Avatar
Awesome info thanks..
CDS31MC
Mar 24, 2023 09:00 PM
2007HHRLT
Feb 8, 2013 07:17 PM
Diskokid
Nov 11, 2012 01:33 PM
asanti
May 29, 2011 03:29 AM
RETRO-RED-EXPRESS
Feb 8, 2011 10:13 PM
