Forged Internals?
Old Sep 2, 2011 | 08:45 AM
nacademus's Avatar
Question Forged Internals?
Can anyone confirm whether or not the 2.2L LAP Ecotec has forged internals? Crank, rods, etc?
Also, a common mod to a 2.2 is a 2.4 intake. Does the LAP already have this wider intake stock?
Old Sep 2, 2011 | 11:04 AM
ZTony8's Avatar
The 2009 and newer 2.2 engines use the same intake as the 2.4 engine.
Old Sep 2, 2011 | 11:07 AM
The 2.2 and 2.4 both feature cast pistons, rods, and crankshafts. The turbocharged 2.0 and the supercharged engine used in the Cobalt SS featured cast and hardened pistons, forged rods, and cast crankshafts.
Eagle and a few others made forged aftermarket cranks for these engines, but I've heard that none are available anymore. The crank in the stock L61/LAP is good for in excess of 500 hp, so unless you go goofy with mods and nitrous, breaking a crank isn't a worry.
I believe the intake on the LAP is the same unit used on the L61 engine, whether the 2.4 intake mod really frees up any usable horsepower is kind of up in the air.
Old Sep 2, 2011 | 02:43 PM
SCE_HHR's Avatar
the le5s prior to 2008 i believe also had forged rods. remember seeing a thread on cobaltss.net about it a while back
Old Sep 2, 2011 | 03:19 PM
nacademus's Avatar
I believe the LSJ had forged rods and crank...
I was just curious if the LAP had it too. I can't find any info about it.
Old Sep 2, 2011 | 10:17 PM
2008 2.4L
The 2.4L VVT uses Forged C70 Steel connecting rods that are shorter than those in the 2.2L with a stroked cast iron nodular crank.
The 2.4 increases horsepower at least 20% compared to ALL 2.2 applications, yet only weighs 13.2 pounds heavier than the 2.2 (which is the lightest four cylinder GM has ever produced).
The Ecotec 2.4L VVT was built at GM Powertrain's Spring Hill, Tenn., Manufacturing facility
Old Sep 2, 2011 | 10:34 PM
hyperv6's Avatar
The LSJ and LNF has Forged Rods and Crank with cast pistons.
I don't think any of the engines are from Springhill right now. THey are all either from Tonawanda NY or Kaiserslautern Germany.
2.2 and 2.4 come with cast pistons, cast crank and powedered rods.
Old Sep 2, 2011 | 10:41 PM
nacademus's Avatar
Dang. I miss my LSJ more and more. :/
Old Sep 2, 2011 | 10:55 PM
Well that's why I said "was" built in Spring Hill (key word 'was').....
And according to a document ChevyMgr posted "2008 model Year Summary" & I printed 8/28/09, the 2.4 has Forged C70 Steel rods.. (edit): not PF rods..
Old Sep 2, 2011 | 11:04 PM
When you get right down to it, with the horsepower levels in our normally aspirated engines, the whole cast vs. forged debate it like splitting hairs. In a modded and hyper tweaked 2.0, you might find forged assemblies advantageous, but for the humble everyday 2.2's and 2.4's out there....it doesn't make any appreciable difference in the long run.
