front brake pads and rotors
FYI GM makes a cast iron rotor for the HHRs. The one that comes stock is a composite rotor and that is the one that warps easy. This is from a dealer, these reduce the tendency to warp, about 6 months ago I had the cast iron rotors installed and so far no sign of warping after having been through winter. We will see.
Ron
Ron
Sleeper, take a photo of your RPO codes in the glove box, and let’s see what your brakes code is.
JM4 would be the ABS 10.86 inch cast iron rotors
JL9 would be from the SS non Brembo 11.6 inch rotors, and rear axle disc brakes
I went thru all the listed rotors and calliper brackets, at the RockAuto site ,all for 2011 HHR, they all pertain to the 10.86 diameter rotors.
Blue- I have the Build Sheet ChevyMgr sent to me long ago. It lists the JM4 (4 wheel anti-lock brake system).
So the original owner musta did the swap, cause I do have the SS 11.6" rotors, I checked that way back when I painted the calipers etc.
All these years I just assumed mine came stock with SS rotors.. the Code doesn't list any size, but if I needed parts I would have learned the hard way..
