View Poll Results: What Grade Of Fuel Do You Use?
87
300
64.38%
90
55
11.80%
93
107
22.96%
Ethanol
0.86%
Voters: 466. You may not vote on this poll
Fuel Grades
Old Jun 5, 2006 | 12:28 PM
Low Tone's Avatar
Fuel Grades
What fuel grade do you run in your HHR? Do you think the performance is affected by it that much?
Old Jun 5, 2006 | 12:34 PM
I use 89 or better. Depends on the difference in price. Haven't noticed any drastic changes in performance from one grade to another. Most of the time I don't even remember which grade I have in the tank!
Old Jun 5, 2006 | 12:37 PM
courthousedeb's Avatar
I haven't noticed any difference from one to the other...so I just get the regular unleaded.
Old Jun 5, 2006 | 12:39 PM
captain howdy's Avatar
Only 93. Where do you find 90 octane gas? Around here it's 87,89,91, or 93. I don't believe anywhere around here sells Ethanol but it makes no difference because the HHR isn't a flex-fuel vehicle so it can't use it.
Old Jun 5, 2006 | 01:08 PM
oldschoolfreak's Avatar
being a gear head i have used all the grades in my 383 stoker engine and i must say it ran best on the high grade stuff 93 octane!! would not even start on caseys crap had to drain it in their lot!! I would say its more noticable in a bigger more performance engine but using cheap gas will cuse problems in the long haul dirty plugs, injectors, scaring in cylinders etc.. (you get what you pay for) i wouldnt put generic oil in my car so why use generic gas!!?? also you will get better gas mileage with a cleaner burning fuel so you realy dont save anything buy buyin the cheapest!! just have to buy more of it
Old Jun 5, 2006 | 01:44 PM
WHITEHHR1's Avatar
you can run ethanol in your hhr
i used to run in a 1990 chev corica
7 yrs ago we have had ethanol in canada for about 9 yrs
good octane level
used to be half the price of gas now the same price
only bad thing is if you store your auto do not leave ethanol in system it will eat away the orings in the foue lines and injectors and tbi's
Old Jun 5, 2006 | 02:12 PM
SindyDix's Avatar
I use 91 here in California. The higher octane is recommended in the owners manual for the 2.4 engine, although not required.
Old Jun 5, 2006 | 02:17 PM
txsman2930's Avatar
I use my ol' grand pappy's moonshine. 100 proof. I reckon' my sled giddyups faster than a bullet out of a gun. I just use the 87 grade depending on the gas station. Once a month, I'll fill up with 93 just to clean out the injectors.
Old Jun 5, 2006 | 03:28 PM
Firewatcher's Avatar
I was using plain old 87 octane until a couple of weeks ago. Now it seems that everyone has changed to the 10% ethanol mix. Mileage wise....seems to be the same.
Old Jun 5, 2006 | 07:22 PM
Navyflyer11's Avatar
I've just used 87 since I got mine back in Aug. No problems.
