View Poll Results: What Grade Of Fuel Do You Use?
87
300
64.38%
90
55
11.80%
93
107
22.96%
Ethanol
0.86%
Voters: 466. You may not vote on this poll
Fuel Grades
Old Jun 5, 2006 | 07:51 PM
TNHHR1's Avatar
89....probably not needed....but old (V-8) habits are hard to break...
Old Jun 5, 2006 | 08:02 PM
TomsHHR's Avatar
I use mid or high octane on trips for the better mileage. in town just the 87 for me
Old Jun 5, 2006 | 11:39 PM
Tokyo's Avatar
Shnog sips 91 from a diamond-encrusted chalise...
Old Jun 6, 2006 | 12:14 AM
SoCalHHR's Avatar
HHR 1 Gets Shell V-Power......and a bottle of Turbo 108 as a chaser!
(actually it's the other way around!)
Old Jun 6, 2006 | 12:57 AM
guido099's Avatar
87 recommended...87 it gets...stop waisting your money!
Old Jun 6, 2006 | 01:02 AM
SoCalHHR's Avatar
If you have a 2.2 it is.
For the 2.4L, 91 or higher is recommended:
(from the manual)
Gasoline Octane
If your vehicle has the 2.2L L4 engine (VIN Code F),
use regular unleaded gasoline with a posted octane
rating of 87 or higher. If the octane rating is less than 87,
you may notice an audible knocking noise when you
drive, commonly referred to as spark knock. If this
occurs, use a gasoline rated at 87 octane or higher as
soon as possible. If you are using gasoline rated at
87 octane or higher and you hear heavy knocking,
your engine needs service.
If your vehicle has the 2.4L L4 engine (VIN Code P),
use premium unleaded gasoline with a posted octane
rating of 91 or higher.
You may also use regular
unleaded gasoline rated at 87 octane or higher, but
your vehicle’s acceleration may be slightly reduced,
and you may notice a slight audible knocking noise,
_________________________________
The 2.4L engine's variable valve timing takes full advantage of higher octane fuels. With a good octane booster, the power increase is even more noticeable.
Old Jun 6, 2006 | 01:16 AM
guido099's Avatar
(from the manual)
Gasoline Octane
Sorry meant to add that Thanks Mike your Quick and/or have a lot of free time
Old Jun 6, 2006 | 11:46 AM
SoCalHHR's Avatar
Notice the time of my post. Only took a second to cut/paste it out of the Owner's Manual on my desktop.
Old Jun 6, 2006 | 11:55 AM
hvrod's Avatar
Originally Posted by SindyDix
I use 91 here in California. The higher octane is recommended in the owners manual for the 2.4 engine, although not required.
Had mine tune to accept 87 - 89
Old Jun 6, 2006 | 12:09 PM
Firewatcher's Avatar
Now, I bet the Captain can point out a thread but I'm gonna ask anyway....I know that ethanol is bad news unless your engine is specifially designed for it, but what about 10% ethanol? It seems all of the stations around here have changed to it. Will we (2.2 and 2.4 owners alike) suffer any damage from this?
