Fuse box issue?
Old Aug 24, 2020 | 07:55 PM
brittlm's Avatar
If you've only had the car since February, how would you know for sure about recall work that was supposed to be done in 2014 ?
And, as Donbrew stated, there were 2 recalls. 1st was for the key cylinder. 2nd was for the ignition switch and 2 new keys.
I called one of our local Chevy dealerships and gave him the VIN on my car.
Old Aug 24, 2020 | 07:59 PM
brittlm's Avatar
also, I just found the slip the mechanic gave me initially. He wrote “no power to neutral switch from under hood fuse box”
Old Aug 24, 2020 | 09:06 PM
If the mechanic checked the fuse box halves of the underhood fuse box, and tge car runs after the ignition is turned off , is he positive it’s the fuse box, did he test the ignition switch? Just because it was replaced during the recall in 2014, doesn’t mean it isn’t worn out now.
Old Aug 24, 2020 | 09:19 PM
Bonez's Avatar
Has the battery been tested ? How old is it? Have you disconnected it for 30 minutes and reconnect it to reset everything in the system?
LadyBee
Jul 10, 2022 01:15 PM
Radco
Oct 18, 2020 12:04 PM
Truckette
"How To" Tutorial Library
7
Aug 31, 2020 09:37 PM
JMAM
Jul 5, 2018 02:35 PM
Dunpokethebear
May 13, 2016 10:06 PM
