Fuses falling out
Old Aug 30, 2017 | 06:26 AM
Axelbeam's Avatar
Fuses falling out
i tried looking for anything similar to this and couldn't find any posts about it so here is my dilemma i thought i knew what i was doing when i went to put in my stereo. in my install kit there was a pigtail to add on to one blade of the fuse for the remote power well i added it to my ignition fuse and it spreed the contacts out so far nothing will stay in. my question is does anybody have disassembly instructions for the fuse box or does anybody know what wires i can cut to add an external fuse holder. i tried reading the wireing diagram but couldn'y make heads or tails of it
2006 hhr ls
thank you all
Old Aug 30, 2017 | 07:10 AM
Welcome to the site, which fuse panel? Interior in the console or the fuse box under the hood?
Old Aug 30, 2017 | 07:43 AM
Axelbeam's Avatar
Sorry about that it's the interior in the passenger side left kick panel
Old Aug 30, 2017 | 08:07 AM
There's not a whole lot of information on removing the panel
There has to be fasteners there somewhere, please disconnect the negative post at the battery first. (I know you knew that)
Old Aug 30, 2017 | 09:29 AM
The wiring diagram should have wire color codes. The horizontal connector at the bottom is C1/X1, the vertical connector is C2/X2. The large red one is C4/X4. Some years they use C for connector other years they use X, but the numbers are the same.
I would start by probing wires in C3/X3 for the kind of power you want, ign, constant, retained. Generally any wire with red on it in any combination is Bat+, pink is ign, brown is accessory. Probe to be sure!
Don't cut a wire; just strip a bit so you can wrap the end of your wire around it, or use a tap.
Old Aug 31, 2017 | 07:57 PM
DentedHHR's Avatar
Just (deform) bend the metal tabs of the fuses a little bit so that the bend holds them in place.......problem solved.
roberttx
Sep 23, 2021 07:48 AM
pitbull76
Dec 12, 2010 10:05 AM
stephensj88
Jul 23, 2008 07:55 PM
HHoRange07
Apr 27, 2008 12:07 PM
Desert Coyote
Mar 18, 2007 10:25 PM
