Got it Lowered...
Old Dec 8, 2005 | 09:24 AM
captain howdy's Avatar
I cracked one of my headers on my Mustang coming out of a steep driveway. I scraped my exhaust really hard and it put to much pressure on the manifold and the weld busted. Thats the whole reason I put on better flowing headers on. Why replace the stock unit when you can get better.
Old Dec 8, 2005 | 11:46 AM
SoCalHHR's Avatar
Originally Posted by JoeR
Mike, have you had the alignment checked yet? From the pics (nice!!) there appears to be some negative camber in the front now. That'll wear the fronts on the inside pretty quickly.
How about letting us know if you get it checked and if you do, how the alignment ended up and what was needed to correct it, whether with factory adjustments or if a kit (usually offset bolts) was needed.
Lookin' good!! Thanks!
Joe - it is always a good idea to put at least 1-200 miles on a new set of springs before getting the alignment; they need to break in and settle. That said, it is very important to align after dropping. I will be going in to my guy this week to have it done. An alignment is required after lowering cars - it is not an option.
The HHR used splind bolt - but they are NOT offset. I'll let you guys know after we align it what is necessary. Basically, whatever they use on a Cobalt works - it's the same setup underneath.
BTW - the neg camber doesn't look that bad in person at all. The tires would need to be driven more than 1000 miles before a wear pattern will set in.
Old Dec 8, 2005 | 12:09 PM
JoeR's Avatar
Gee, I would have thought you put those 1-200 miles on it within the hour!
Very much in agreement on the requirement of alignment. Let us know how it goes.
How about the ride? Did you notice much difference? From talking to Erich about the Goldlines and Eibach there is only about a 20% rate increase, which should make the ride a little firmer, but not harsh.
Old Dec 8, 2005 | 12:43 PM
SoCalHHR's Avatar
Well...actually I did put 135 miles on it on the way home!
The ride? Yes, a bit firmer, but not at all harsh. *Remember, I'm currently running 16" tires, which adds a BIG "cush" to the ride. With 18's, it's gonna get a bit rougher. Erich did tell me that none of the customers (of all different wheel sizes), has complained about the ride yet.
More info after the alignment...
Shanes0406
Jul 20, 2015 04:08 PM
dgrabes
21
Feb 8, 2013 12:44 PM
xzombiex66
28
Sep 2, 2008 09:53 PM
elliot
Dec 18, 2006 06:04 PM
JOEK86
30
Aug 23, 2006 07:57 AM
