Have code C0040
Old May 14, 2025 | 05:42 PM
PAULHHRHELP's Avatar
Have code C0040
Originally Posted by Oldblue
Check the wiring connections for corrosion or damage, Replace both front hubs not just one!
https://www.engine-codes.com/c0040_chevrolet.html
So is just had both front hub assemblys replaced on my car and it's still giving me that same code after replacing them. Any help would be greatlyappreciated!!!
Old May 15, 2025 | 06:40 AM
PulpFriction's Avatar
What was your issue? If it was P0035/40/45/50, it is probably a bad wire or connector. Always check those first. These cars are old. The wiring insulation can look fine in the outside and be corroded and/or broken on the inside. That might mean continuity/resistance checks on every every wire.
Old May 15, 2025 | 06:44 AM
PulpFriction,
Thank you so much for your help! I will have it checked! I am not a mechanic by any means lol.
I had this code a year or two ago, it was the hub, and the replacement hub was faulty. The harness from body to hub is obsolete, you will have to replace the wires
Old May 15, 2025 | 06:45 AM
Thank you for the information!!
PanamaJack
Jul 11, 2016 10:14 AM
NxlKing2304
Feb 14, 2014 07:41 AM
edgarfrog
Oct 25, 2013 08:43 AM
LtGhost08
Jun 10, 2013 02:13 PM
mrkil
Canadian Mid East
Sep 2, 2012 01:19 PM
