header install caused leak?
Old Mar 12, 2021 | 02:44 PM
Henrythetintguy's Avatar
Stainless Header causing coolant leak.
I had the same problem 08 2.2...stock cast header cracked down center leaking exhaust..figured go with stainless..after install was leaking antifreeze. ..2 center pipes were pushing on coolant tube below...easy fix.. I just removed it an got out my sledge hammer tapped flat spot on the 2 center tubes. about Quarter to half inch......reinstalled no more leak....I didn't use heat or torch.. no welds were harmed... but I would recommend heating before tapping..
intofocuszx3
2.2L Performance Tech
89
Feb 25, 2013 08:56 PM
skyline26
Mods - Engine/Exhaust
Jan 12, 2013 02:41 AM
capp002
Jul 16, 2010 05:12 AM
1Panel2NV
Feb 21, 2009 08:13 PM
Vinny
2.4L Performance Tech
Aug 13, 2008 06:03 PM
