Dimmer control interior lighting
Old Mar 13, 2021 | 02:28 PM
richardfre's Avatar
Thumbs down Dimmer control interior lighting
My dimmer dial is not working on my 2011 HHR, only the dome light is working, What can I do to fix it?
Old Mar 13, 2021 | 02:41 PM
Replace the dimmer?
Old Mar 13, 2021 | 04:26 PM
You could try a squirt of electrical contact cleaner, but replacement is the best way to fix the issue, send hellshotrod a PM , he should have one, he parts out HHR’s look in our retired Classified Ads
https://www.chevyhhr.net/forums/reti...wanted-ads-16/
Or order one from RockAuto
https://www.rockauto.com/en/catalog/...er+switch,4532
Don’t forget the discount code
https://www.chevyhhr.net/forums/supp...-2021-a-61707/
Old Mar 13, 2021 | 04:33 PM
richardfre's Avatar
Thank you.
Do you know how to change it out?
Old Mar 13, 2021 | 05:13 PM
Stick your fingers into the AC vents and give a sharp yank to pull the "waterfall" off. Then remove the switch and install the new one.
Old Mar 14, 2021 | 10:10 AM
richardfre's Avatar
Thank you, I'll check that out.
Rcflyboy
"How To" Tutorial Library
23
Aug 27, 2016 08:24 PM
ken531953
Sep 3, 2013 07:41 PM
ballwinguy
12
Feb 26, 2010 12:50 AM
08redhhrss
13
Oct 6, 2008 10:07 PM
Rebel13
61
Apr 26, 2007 11:23 AM
